omnitonic
- Michael
- Apr 20, 2021
- Southwest Virginia
- 2021 JLU Willys in Sarge Green
- Occupation
- truck driver
I have the 3.6L 6MT and 3.45 gears. This table neatly summarizes my options:
Sitting on my current wheels and tires, I'm getting an overall average of 20 mpg I currently use 6th and 5th on the way to work, and 5th and 4th (and occasionally 3rd) on the way home. The grades are much steeper on the way home.
It looks like 4.10 is a good compromise in terms of fuel economy. I get my cruising RPMs up a lot closer to the sweet spot at 2000 while still having some room to lug along if I want. If I already had 4.10 gears, I would probably just stay there.
If I go to 4.56, I end up turning a little high in any of the gears I would normally use at 70 mph. I currently spend a lot of time in 5th, so I guess it's really only about 150 RPM. On the other hand, when I currently do downshift to 4th, I can see those fuel economy numbers drop like a stone, and that is only 300 RPM higher than I would be running in the new 6th gear.
One of the things that's making this kind of hard to puzzle out is that there is basically no flat stretch of road anywhere around here so I can cruise at 70 on flat ground in each of the three gears. I notice I get worse gas mileage at wide open throttle than I do if I'm at, say, 50% throttle. Driving around in something close to the equivalent of my current 4th gear all the time might not be as bad as I think. I am currently only seeing the fuel economy plummet whenever I'm in a wide open throttle situation. At other times, I am normally in 5th or even 6th.
So that's why I'm writing all this up. I'm looking for folks to share experiences they've had. I have a feeling y'all are going to talk me into the 4.56 gears. I'm leaning that way, but I need more convincing.
Running at 70 mph
4th | 5th | 6th | |
3.45 (current) | 2531 | 2055 | 1822 |
4.10 | 2755 | 2232 | 1984 |
4.56 | 3064 | 2482 | 2206 |
