Head Gasket at 50k
Cheyenne
New York
2022 jeep jl 2.0 turbo
I called Endurance for a warranty quote and the guy told me that price was high due to typical head gasket replacement at 50k. I looked this up and it indeed seems like a problem for the 3.6 engines. I have a 2.0 turbo. Should I expect this to happen? I'm at 49k.
kah.mun.rah
Merenkahre Jr.
Duat
Use your powertrain warranty from the factory (dealership).
Heimkehr
Pennsylvania
2021 JLU 2.0T
No. While head gasket replacements aren't unknown on any engine, they're not a recurring issue on the 2.0Ts to the extent that, for example, failed seams on that engine's pressurized coolant reservoir tanks occasionally are.
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
Biggest issue in the 2.0 is when the cooling fan kicks in. Factory has it kick in at 225 and thats WAY too hot. Do yourself a favor and install a different fan controller. In my opinion its the best way to prevent/limit heat issues. This could actually also help with the 2.0 Coolant reservoir splitting due excessive heat to some degree
http://www.rpmextreme.com/Product/311/Jeep-JL-PWM-FAN-CONTROLLER.aspx
NWJeepr
Twin Peaks
2025 Wrangler 2-door
In short, no, you shouldn’t expect it to happen on a 2.0.
You should be vigilant regarding coolant leaks and keep an eye on the coolant reservoir, both of them, and check the black one often. It’s prone to splitting and leaking, which can then lead to an overheating condition.
7c102c600853ce38121
Marek
Europe, Poland
21 EU JLUR
aluminum heads.......multi layered head gaskets......high temp operating conditions........poor fuel........torque to yield bolts........turbo..........what could go wrong :)
not…….much…as……….it seems….from……. 7…..years…..of….production………. 🙂
Cheyenne
New York
I know. I bought a backup and keep it in the Jeep.
Rogersocal
Roger
Do you have an install thread?
I dont think there is a install thread, but i know there are a couple discussions about that fan controller on these forums
Cheyenne
New York
Hi this makes sense. The site says I can order positive negative or can only. Not going to pretend that I understand this. Maybe you can tell me which? Will have my mechanic install it.
Rogersocal
Roger
The Can bus only means that it only reads and reacts to temps and does not allow for outside triggering like from a switch. The outside triggering allows you to override the controller and push your fan to full on. The pos/neg just means are you switching ground or are you switching power for that switch.
I got mine as Canbus only. I saw my temps drop from the 215/220 or higher to right about 195 with the new controller. Yes when you step on it the temps climbs but quickly drops back down as the fan controller reacts.
Th install isnt "Hard" but you will be cutting/splicing/ soldering wires at ECU. I would recommend disconnecting the battery for this, although i didn't but im used to working with live power on a normal basis.
NWJeepr
Twin Peaks
More curious than anything, but why do you think 225 is "too hot" ?
Rogersocal
Roger
My ram 2500 6.7 pulling 10klbs runs at 195 degrees, My wifes pilot runs at 180-200. Most cars will run right around 200. An additional 25 degrees for just putsing around town is pretty high. Now step on it and watch it climb to 230, 235. Heat is one of the main ways to kill an engine.
