Grinding noise 4-low while turning - Driver front
smon222
Stephen
Greenwell Springs, Louisiana, USA
2023 Willy's Xtreme Recon, Acura MDX, Honda CRV
Filmmaker
2023 Jeep Willys XR 2700 miles
First time to go in 4-low on my 1st Jeep ever so I am wondering if this is normal. I went offroading this past weekend and didn't notice the noise until the end of the day when I put my top back on and no radio so it was quiet inside. Noise is only on the driver side front under the dash.
Otherwise, everything drives great, its just that strange grinding and only in 4-low, not sure about 4high(didnt check)
I attached a video, is this normal or what could it be?
Thanks!
smon222
smon222
Stephen
Filmmaker
Upon further self-diagnosis, I think this may be a normal sound of the limited slip in the Jeep Willys Extreme Recon.? I got in my wife's 2023 Willys Extreme Recon and it has the same noise while turning in 4L.
OminousSkitter
The Ether
Trek Bicycle
It is hard for me to hear what is going on in that video, but I can say if you're driving in 4WD on a high-traction surface (e.g. dry road), when you turn more than following the gentle bends in a road—especially 90º turns—, it will sound and feel like your tires are skipping due to the different circle circumferences and applying power to both wheels on the axle. It's not related to LSD because neither wheel is slipping. This will happen in 4H or 4L on the front wheels.
I know my rear LSD does not make noise when it is working.
smon222
smon222
Stephen
Filmmaker
I just tested it in 4H, the sound is still there but only noticeable during sharp turning. I was testing it in the back yard on the grass. When I originally noticed the noise it was at an ORV park on the trails.
Riotfunk
Ma
22 Willys with 2 Doors
Are you turning on pavement in 4 low?
smon222
smon222
Stephen
Filmmaker
No, the first time I noticed it was on the trails. When I am replicating I am doing it in the grass in the back yard.
OminousSkitter
The Ether
Trek Bicycle
Grass in the back yard could still be high enough traction that your tires aren't slipping. Same at a park depending on the type of surface on which you're turning. My answer would still apply (but it's possible you're experiencing something else).
lindaspins
Linda
Burton, OH
2015 JKU Rubicon Hard Rock
Loose ball joints?
smon222
smon222
Stephen
Filmmaker
Apparently, it's a common issue with the Jeep Nanny systems and the breaks during 4L & 4H. The link above shared by OminousSkitter is pretty interesting and is exactly the same thing I am experiencing.
Deleted User 38384
I call it skipping myself. I think all Wranglers do it. Honestly I think all vehicles with a four-wheel drive mode do it. I've even had my tire skip on dirt. It was hard dried dirt, but it was still dirt. Only time it doesn't happen for me is if I'm on soft loose dirt.
OminousSkitter
The Ether
Trek Bicycle
Yes, I call it "skipping", too, when the tire skips. But if you're turning tight in 4WD the tire must either slip or skip, which is what I was trying to say. If the traction is high enough that your tires don't slip, they'll skip.
