GMRS Antenna Install Question
bsmith
NJ
2005 Jeep TJ 2021 Rubicon
I will be installing a Midland MXT275 GMRS radio and a Midland Ghost antenna. I intend to mount the antenna on one of my cowl/ditch light brackets. I was going to fabricate a bracket “extension” out of a piece of scrap aluminum plate to mount the antenna outside of the light. It would just be a 6” oval strip bolted between the light and the bracket with the antenna on the other end. I remember reading something about ground planes for antennas and know nothing about this topic. The cowl light bracket is also aluminum but has a steel mounting bolt. Will this work? Should I use steel as the extension?
cornercanyon
bruce
Texas Hill Country
2014 JKUR, 2021 JLUR XR
. . . realizing each day–
All the current Midland antenna offerings require a ground plane to perform as expected. In general the minimum size for a ground plane is considered a ½ wavelength across or about 12” for GMRS frequencies. Steel or aluminum can serve as a ground plane and it doesn’t need to be a continuous plane. Some antennas like the MXTA26 may perform acceptably without a ground plane, while others such as the MXTA25 may perform poorly without some ground plane.
Which antenna did you get?
bsmith
NJ
I bought the Midland MXTA25 3.5” Ghost antenna. I haven’t bought the radio yet, just the antenna. I’m doing another install right now and took a bunch of the interior trim panels off. Figured easier to do it this way. I will be getting the Midland MXT275.
Will the ground plane ”continue“ from my DIY bracket through the light mount and bolt and through the body of the Jeep? GMRS aid new to me and I don’t know anything about it. Thanks for the help.
Cycle11111
Alastair
Truckee CA
2019 2 Door Wrangler Sport
I use two antennas for my Wouxun KG-1000. When running normally I use a 6db dual band VHF/UHF antenna as the KG-1000 can receive VHF. I also have a ghost antenna similar to what you have to put on when running on treed trails to avoid the antenna pounding on the A-pillars etc. I mount both of my antennas where the FM/AM antenna normally mounts - I never ever listen to AM/FM and use satellite or my phone to stream. Both antennas perform very well in those locations.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
Here's my setup. Ordered this bracket on Amazon and mounted it with a piece of neoprene behind it to prevent scratches. I have the MTX275 with the 6db antenna and easily reach LOS repeaters from out to 50 miles.
It also perfectly matches the am/fm antenna on the other side if your asthetics demand symmetry...
Jeep Wrangler JL GMRS Antenna Install Question 20210208_150541
Jeep Wrangler JL GMRS Antenna Install Question 20211006_203044
Jeep Wrangler JL GMRS Antenna Install Question 20210208_150533
Speed331
Sean
Las Vegas, NV
I do the same thing with the ghost antenna. It gets swapped in if we're going to be running tight canyons/heavy forest trails where I'm only talking to the group on the trail. But otherwise, since I'm in a big desert valley and use repeaters frequently, the 6db is my standard because of it'a great range.
cornercanyon
bruce
Texas Hill Country
In the past I have used both the MXTA 25 ghost and MXTA 26 whip with the MXT275. Both have been rear tire carrier mounted on a small piece of stainless steel. The SWR (Standing Wave Ratio, essentially the resistance to sending your signal) of the whip in that position is far better than the ghost.
I would guess @Speed331 's solution is also more effective for the whip though suitable for the ghost.
On most trail runs even my Yaesu handhelds are effective for communications between us. Either may likely work effectively when the parties are traveling together—
Speed331
Sean
Las Vegas, NV
I lucked out with the 6db I received, my SWR is 1.3 to 1.6 through the gmrs range, throws a nice clean signal. I tested my repeater connection out at 35 miles while changeing the orientation of the jeep and no one could hear a difference.
I've read reviews where it's been tuned slightly too long/short and getting readings in the mid 2+ out of the box. But that was a few years ago and the recent reviews suggest Midland's gotten better consistancy as of late...
I never tested the ghost's SWR 'cause I figured it is what it is and only needed a few miles of range at most.
bsmith
NJ
I‘ll probably buy the second antenna for those times I might need it. I like your mounting location too. Never listen to AM/FM either.
bsmith
NJ
That looks good, I may go that route too. I was thinking to minimize the brackets since I already have the light brackets.
Cycle11111
Alastair
Truckee CA
Exactly. The Ghost antenna gives plenty of range for trial runs. Running around to hit repeaters etc the 6db is the jam. I will be mounting a HAM radio as well so need to sort that antenna setup
Speed331
Sean
Las Vegas, NV
It's a solid bracket. It's been on for 2 1/2 years now and the finish still looks great.
The bolt that came with it was the wrong thread size however and the existing bolt was too short. Luckily, I have T-handles holding my hard top down and a spare bolt from those worked perfectly.
bsmith
NJ
I was thinking of the tire carrier mount as well. When I installed the Mopar flat tow wiring harness, I removed most of the trim front to rear, including the subwoofer panel, and it was a PIA. Right now I am installing the Rockslide Engineering steps and have the door trim removed to install the door sensors. If I get motivated, maybe I’ll keep removing the trim so I can run the antenna cable from the tailgate.
cornercanyon
bruce
Texas Hill Country
Once you have done the subwoofer and know what to expect, doing it again is not so bad.
I am no radio expert through I think the front mount is considered a better location. Check out this guy's youtube's: informative and amusing
bsmith
NJ
