Getting just a bit more height...
DHW
Atlanta
2018 Rubicon
Attorney
Hey guys,
Suspension work is the one thing I'm not keen on doing, and probably what I understand the least about my Jeep. I've had the Mopar 2" lift on my 2018 Rubi pretty much since right after I bought it in early 2019. I also have adjustable front and rear track bars, but the axles never shifted enough to warrant adjusting them. I'm also running 35" MT Baja Boss ATs.
I have a lot of weight on my Jeep (bumpers, winch, etc) and I'm looking to get an additional 1" of lift and want to see what my best options are. Spacers? New lift? Can I just get new springs?
I really don't want to buy a whole new lift and would like to avoid (as much as possible) additional parts required to keep everything in spec with the additional 1" of lift. What do you guys recommend?
Jeep Wrangler JL Getting just a bit more height... unnamed
Punkn89
Alex
Maryland
2019 Wrangler
The problem if you even go 1” taller, you’re going to throw the geometry off so you’ll need to think about new adjustable control arms or drop brackets. If you go above 3.5” you’ll want to consider a drag link flip kit, or maybe that is 4”, don’t remember. You’ll need to make sure your sway bar links are long enough as well as shocks.
I’ve seen conflicting info on the mopar lift on how many inches it actually gives. I’m sure yours has settled quite a bit. The best thing you can do is to get under there and measure everything.
  • Like
Reactions: DHW
DHW
DHW
Atlanta
2018 Rubicon
Attorney
That's my concern. I guess my question is what's the least complicated was to get that extra 1".
jadmt
jeff
montana
how much actual lift do you have using this diagram?
Jeep Wrangler JL Getting just a bit more height... IMG_0527
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Least complicated would be to put 37's on it. :CWL:
MOOG5050
Ny
Rubicon XR
Gut fenders or replace with KBD and add new inners and 37s.
DHW
DHW
Atlanta
2018 Rubicon
Attorney
Bolt to bolt, little over 21”
Tube to cup lip, slightly over 12.5”
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
1" spacers are cheap. Try them, get it aligned, and see what happens.
jadmt
jeff
montana
if you wanted to spend $1517 an AEV 2.5 lift would get you another 1.5" :)
DHW
DHW
Atlanta
2018 Rubicon
Attorney
I was actually considering the AEV lift cause I've heard good things about the ride, but I've also heard a lot of people who have it say it actually lifts the Jeep about 4" and doesn't really settle.
jadmt
jeff
montana
with your weight it won't lift it 4" I have zero weight ie stock plastic bumpers and unloaded and am at 4" it rides and handling is amazing. I am confident when I add a bumper/winch it will come down. when running trails I will have either my Yeti cooler or ARB fridge and tools in the back so that will settle the back down. I offroad a lot but still in reality am going to be spending more time on the road. I try and hit moab a couple times a year but it is a 1600 mile roundtrip so nice having a good driving road rig too.
  • Like
Reactions: DHW
DHW
DHW
Atlanta
2018 Rubicon
Attorney
I'm looking at your profile pic. What size tires do you have?
jadmt
jeff
montana
255/85-17 ie 35x10 pizza cutters. mickey thompson baja at's
  • Like
Reactions: DHW
