Gang switch issues
BetOnBlack
Princeton, TX
2019 Rubicon Unlimited
Supreme Leader of IT
Hey all,
Hoping someone that has encountered something similar can help.
I have a Nilight 6 gang switch pod set up (rebadged Auxbeam) with front bumper lights and wheel well lights. It's been working fine until today (day after Amazon return window closes).
So it was working turned the Jeep off, 5 minutes later I came out turned the Jeep on and now the button panel is lit up like normal, but when pressing the buttons it powers on the device for a split second then it turns off that light. The panel never loses power. It does flash if you hold the button down.
I checked all fuses and connectors. Moved the devices to 12v direct power from the battery and they work fine.
Hope I can find a fix and don't have to rewire this whole thing.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
The lights, wiring, fuses, and connectors are all good. I'm just brainstorming here but I'm thinking it's the switch Pod. Are you using a relay?
