Fuses
kipco
Indiana
2018 jeep wrangler unlimited Sahara
What location will I find my windshield washer pump fuse?
the owners manual doesn’t give it.
kipco
kipco
Indiana
2018 jeep wrangler unlimited sahara
AndySpill
Andy
Pittsburgh
2018 JL Sahara
15? (front at least, 14 for back if equipped)
Source https://www.jlwranglerforums.com/JL-Wiring-Diagrams/WIPER_WASHER-SYSTEMS.pdf
Access
https://www.jlwranglerforums.com/forum/
Select "Electronics, Electrical, Uconnect, Nav, A/V, CB, Comms, Cameras - Sponsored By WOLFBOX" as linked below
https://www.jlwranglerforums.com/fo...-a-v-cb-comms-cameras-sponsored-by-wolfbox.9/
Select "JL Wiring diagrams" as linked below
https://www.jlwranglerforums.com/forum/threads/jeep-jl-wrangler-wiring-diagrams.19185/
Select Wiper Washer Systems (the last entry) as linked at the top of this post.
Terrymo
Terry
2023 JLURXR 3.6 ET
On mine removing Fuse 27 which is for the front wipers or Fuse 15 has no effect on the windshield washer pump. I’m probably misreading the post of @AndySpill Is the windshield washer pump specifically fused?
kipco
kipco
Indiana
That is what I am trying to find out my pump doesn’t work front or rear. Wipers work fine…
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@kipco
With engine compartment hood open, stand by the engine compartment and have someone
else initiate front windshield wash.. When they do this do you hear the fluid pump in the engine compartment power up and make noise?..... and pump no fluid... If so.....
Good chance your JL's reservoir filter is plugged.... If you hear pump working and no fluid is being moved/dispersed, filter is plugged.
What washer fluid brand do you use?
Terrymo
Terry
2023 JLURXR 3.6 ET
@kipco
Is the windshield washer pump fused? I don’t know why I thought I remembered reading it wasn’t?
kipco
kipco
Indiana
@kipco
Good chance your JL's reservoir filter is plugged, if you hear pump working and no fluid is being moved/dispersed.
Tried this already wipers wipe but I hear no pump trying to work and not sure what fluid is in it we just bought it last Friday and it’s been raining like crazy here in Indiana it stopped today so I bought new wipers and put them on and thought to myself I haven’t tried the washer yet and the low washer light has been on so I popped the hood to fill it up and it’s full so now my pump doesn’t work and the low level sensor is bad I’m guessing???
Terrymo
Terry
2023 JLURXR 3.6 ET
I know this is trivial but I can’t find the answer. @mwilk012 or @alphawolff does the windshield washer pump have a fuse, and if so what fuse number? Anyone?
yokramer
Snark Incarnate
Terrymo
Terry
2023 JLURXR 3.6 ET
No fuse, direct power and ground on a reversible driver from the BCM.
Thank you. Searching just showed the fuse question repeatedly unanswered, but I thought I was understanding the wiring diagram to show it was unfused.
yokramer
Snark Incarnate
So best bet is pull the liner out get to the pump and see if its getting power, if it is bad pump if its not bad jeep
