Fuse F08 TCM
Cat4
Jake
Washington
2022 392 XR
Having some shifting issues and wanted to see if resetting the TCM would help. I pulled the F08 fuse, started the Jeep and to my surprise there was no warning or CEL at all. I even shifted into drive and nothing out of normal happened. I triple checked that I pulled the correct fuse. Does this make any sense? I've pulled other fuses and have always received some kind of message on the dash.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Fuse 8 is main power supply to tcm. It should cause a host of problems. Wouldn’t try driving without it installed.
Cat4
Jake
Washington
2022 392 XR
This will be a fun one to explain to the dealer… Can anyone confirm they get dash lights if the fuse is pulled?
mwilk012
Oklahoma
Service
Why would you? Leave it alone.
Cat4
Jake
Washington
2022 392 XR
I’ve taken it to several transmission shops and they all agree that there is some kind electrical/programming issue with the transmission. Dealer keeps saying there’s no issue. It just seems odd that the fuse isn’t doing anything (or anything obvious) and may point to a diagnosis. Just spitballing here.
mwilk012
Oklahoma
Service
Whats the actual problem? Rough shift? No shift? Gear skipping? Slipping?
Cat4
Jake
Washington
2022 392 XR
From 6-5 and 5-4 the downshift is rough enough to make an audible clunk, makes it very hard to brake with consistent pressure on the pedal. When on the gas in 2nd and then release right before it would go into 3rd it clunks into 3rd. Also very confused and rough shifting at low speeds.
mwilk012
Oklahoma
Service
Have you driven any other JL’s to compare? How many miles are on yours?
“Audible shift” isn’t a problem per se.
