Front track bars vs relocation bracket
Bluebeast
Travis
NorCal
2018 JLU sport
So I see a lot of information about people putting adjustable track bars on the front and relocation brackets on the rear. Is there a disadvantage to just using a relocation bracket on the front track bar so the front and back would match?
bmedfo1
Baltimore Maryland
2019 JLUR 4.5" lift 37"s
The difference between the front and back is that the front also has a drag link that you want to keep parallel with the track bar. IMO the axle side track bar bracket is best for the rear. In the front the factory track bar is wimpy and can cause wobble with larger tires putting more force on it so its worth replacing even if you did not need to adjust. From personal experience I would not use a track bar bracket unless you are going big with >4" lift and a drag link flip to keep the geometry right.
Bluebeast
Bluebeast
Travis
NorCal
2018 JLU sport
Thanks. I went ahead with the adjustable front track bar up front instead of the bracket. I did opt for the bracket in the back. Will it matter much if I put one in before the other? I have access to a vehicle lift this weekend and every thing for my lift will be here this weekend with the exception of the front track bar. I was thinking of putting it all on using the vehicle lift and then doing the track bar at home later when it shows up. Other than the fron axle being off center would there be any issues?
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Almost all (if not most) front track bar brackets looks like a pain to install. Requires drilling and not compatible with my sway bar disconnect links.
Oletimer
Darrell
Crystal River, Florida
23 ram 1500 5.7 , 24 392 final edition , 26 F150 tremor 5.0
retired Logging Contractor
No issues do it at your leisure.
SouthCo
MD
2018 JLU Billet Silver Sahara
You should be fine. How much lift? The Mopar 2" lift kit doesn't come with front nor rear adjustable track bars. Doesn't come with drop brackets either and people run it like that.
Bluebeast
Bluebeast
Travis
NorCal
2018 JLU sport
The mopar 2 inch lift. Figured I would need the track bars. I currently have Rubicon suspension on my sport and I can see the axles are ever so slightly off Center so I imagine with the mopar lift they would shift enough to really bother me!
Oletimer
Darrell
It will drive much better getting it squared back up. You may consider a bit of toe in at alignment.
Roky
Roky
Check before and after ride height, if you get 3” or more of lift, you’ll also need caster correction. The fixed arms that come with the kit, aren’t long enough.......:)
bmedfo1
Baltimore Maryland
I lifted mine before adding the adj track bar or bracket axel was way off center but imo an inch or so for the short term won’t hurt anything
