Stormin’ Moorman
So it looks like you replaced the whole floor, even the sides with the tie downs and not just the middle section. Is that right?I mounted the slide to the floor. I took out the factory floor, cut a piece of 1/2” Baltic plywood to the shape needed, used the 6 metric hole locations that the tie down brackets used. Picked up a piece of black automotive carpet at Lowe’s and put a door access to the under floor storage. The DFG slide came with 6 screws that were too long. I picked up a 3/4” version of the same screw at my ace hardware. Just screwed to plywood with pre-drilled holes in slide. The floor replacement took a few hours, but the slide install was less than 30 minutes. It took more time centering the slide so fridge wouldn’t rub on seat and tailgate. Luckily, it all worked.![]()
