Freedom panel misaligned?
ejl12
Maryland
JL
Hi y’all! First time removing/installing freedom panel (I know…) and noticed there is a rubber flap on driver side and that the panels are ever so slightly misaligned. Pics below. Is this normal or did I screw up? Do y’all have that extra rubber bit too or should that be tucked in or something? Thanks for helping out a newbie!
Jeep Wrangler JL Freedom panel misaligned? 78DC5915-7946-4920-8AA0-6BA835088385
Jeep Wrangler JL Freedom panel misaligned? 5538B191-83B8-4FEF-B7F5-6E3ADEFD8A73
Sean L
Sean
North Carolina
It doesn't look out of the ordinary for me. Just to be sure, unlatch the panels and lift up the outer edge an inch and see if the rubber settles in more. Then do the same for the inner edge, that was a problem spot for me when I first got my Jeep.
vasdimpop
Vasil
MY25 JLUR (being built)
I had to adjust my freedom panel when I got the Jeep and now it's great! Just unlatch, lift and resettle.
ejl12
Maryland
JL
Thanks y’all, very helpful. When unlatching and lifting, should I start from passenger side to driver, or driver to passenger? The right order confuses me a ton…
Also, so do you guys both have that rubber “L” shape at front (facing windshield)? It doesn’t seem like mine can be folded in or covered by the top when properly aligned, so my thought was this was normal, though it does look odd from aerial POV.
Killed by Death
North Carolina
2025 Willy's Recon
Yep, my old Rubicon arrived misaligned right from the factory. Service aligned the panels while I was signing the paperwork. Just another thing to add to the delivery check list.
Notorious
North Texas
2000 TJ Sahara
If you’re taking the freedom panels off, the driver’s side has to go out first, the passenger side second.
If you’re replacing the freedom panels, the passenger side goes in first, the driver’s side second.
Following this order will ensure the seals set properly.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
Mine is like that also…doesn’t leak so I’m not messing with it. Unless your 7’ tall it’s impossible to see.
LittleDog
New Jersey
2020 Sahara JLU
My passenger-side is slightly more forward as well. There's a how-to on the forums somewhere on adjusting tbat front mount, and perfectly squaring the panels if needs be. But I'd agree that if they don't leak, don't bother.
With regards to Passenger or Driver-side first on/first off, I'm pretty sure they will only latch down properly if the Passenger side is on the 'bottom', as it has a small lip towards the middle of the cabin. You'll remember after mixing it up a few times.
Don't forget that you can also remove the Driver-side panel only, if you so please; I probably do one panel off the most. Just tie the one panel down in the rear footwell of my four-door, takes less than a minute, on or off.
JL_Confidential
Jason
KY
21 Gecko Willys Sport 2-door
I'd tell you, but you know the rest....
Stop looking at it so closely, if it doesn’t leak, it’s good.
Agree to a point. Mine looked like the OP and didn’t leak, but I did have some excess wind noise. Aligning then properly helped with the wind noise.
ejl12
Maryland
JL
Thanks y’all for your help. I’m mostly fixated on this because I’ve been hearing tons of sounds lately coming from the top (popping and creaking, like the clicking of plastic/rubber) that I suspect is from the freedom panels. Hopefully these tips will help get rid of the noises!
LittleDog
New Jersey
2020 Sahara JLU
If you've funny noises coming from above, I'd give the alignment a shot.
Mine's a bit wonky, but no weird sounds. Lots of people here recommend headliners for sound deadening as well.
omnitonic
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
I'd like to add that if you (any random reader, not you specifically) looked at the little diagram in your freedom panel bag, and proceeded to get this backwards, then you ain't the only one. It works much better when you do the panels in the correct order! D'oh!
ejl12
Maryland
JL
So I reseated the panels as y'all recommended and the plastic popping/clicking sounds stopped... but the noise returned a few days later. I reseated once again and the sounds went away. Y'all have any thoughts on a more permanent fix? I've seen tips about lubing the rubber seals or using velcro but curious if anyone has some advice.
