Fire Extinguisher etc for JLU
Sluggo
wisconsin
None
Today I mounted my extinguisher using the threaded holes for the hard top. It just fits. I used wood as the mount as I do not have access to metal working. Only works with the soft top. I had to move it rearward to clear the soft top mechanism. I’m not saying this is a good solution, I may or may not keep it installed. Jeep Wrangler JL Fire Extinguisher etc for JLU E90B6EC1-63BB-43F9-8BA8-B0E8D284DB94
Jeep Wrangler JL Fire Extinguisher etc for JLU A208ED03-0E0D-436E-8140-F3C1DA6DC873
Pic18
RI
2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
I’d encourage you to reconsider your mounting location. If you need it in a hurry, the very back of the Jeep usually isn’t ideal
I keep two, and both are reachable from the driver’s seat.
Hi. Can you share pictures of where you keep them? Thank you.
macintux
Indianapolis, IN
2005 LJR, 2022 JLR
Sure. I assume the JL rollcage is sufficiently different that my setup would require some tweaking (the bars aren't round any more, are they?), but I keep one above and one to the side.
Here's the halon that I keep for use if my Jeep catches on fire. It has a quick release from Drake (https://www.amazon.com/Drake-Off-Road-FIREX-MNT-DOR-Extinguisher/dp/B006VFR2LS), although I use hose clamps instead of the attachments that came with it.
Jeep Wrangler JL Fire Extinguisher etc for JLU IMG_0717
Up close:
Jeep Wrangler JL Fire Extinguisher etc for JLU IMG_0718
For the cheaper one to my left, I just use the mount that came with it, again with hose clamps to keep it in place.
Jeep Wrangler JL Fire Extinguisher etc for JLU IMG_0716
Closer:
I used some sort of putty, don't remember what, to try to keep the release pin from rattling. There are undoubtedly more car-friendly release mechanisms available.
I've also seen quality mounts for directly in front of the front seat, behind your legs. Seems like a reasonable option, but whatever you do, make sure it's secure. Not the kind of object you want flying around in an accident.
Springtail
Doc
Southern Iowa
2018 JLUR, 1977 FJ40, (RestoMod), 2018 Camaro SS Convertible, 2020 Tesla Model Y Performance
Co-Owner Springtail LLC
This is probably a really good option for Jeeps....compact, heat stable and does not expire
Iwant2poop
Abe
Laredo, TX
2014 Wrangler Sport, 2002 Grand Cherokee (Sold)
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
That Element extinguisher looks pretty cool. I think that might be the one to mount in my Jeep. Almost wish it could be Jeep Club endorsed or something.
Zeus
Republic of Texas
07 FJ (+about $30k)/14 4runner on 6112s n Icons (looking at JLURs)
Element looks interesting/great... NEVER use an ABC extinguisher on a vehicle you care about.
