Finally got my wiring for my lights
JINO
Jino
Socal
2021 jlurd
Morimoto finally sent my pigtail.
They emailed saying this won't work with my bigbanger and that I should buy the entire harness kit.
Is this true?
Someone told me that this pigtail was all I needed to wire them to my aux switch.
Jeep Wrangler JL Finally got my wiring for my lights PigtailHarness
Jeep Wrangler JL Finally got my wiring for my lights 20231220_152735
dpike
New Jersey
'20 JLUR 3.6
Depends what connector or if there's a connector on the back of those lights. The aux wires are bare ends so youll need to butt splice into the positive line and put a ring terminal end on the ground to the stud by the battery. I've never used a manufacturers harness, besides for their connectors, to connect any lights, they're usually just a bloated bundle of wires.
ParadigmDawg
Greg
Fort Worth TX
I throw away or cut off about every wiring harness I get. You only need the connectors that plug into the lights if using Aux switches.
JINO
JINO
Jino
Socal
2021 jlurd
That's what I suspected.
Had a feeling morimoto was trying to upsell their harness, which is not cheap.
The one issue, is that these lights have backlighting, I won't be able to use them without their harness, unless I figure out how to piggyback into my daytime running light wire.
ParadigmDawg
Greg
Fort Worth TX
ParadigmDawg
Greg
Fort Worth TX
I'm not sure I understand what that would do.
It has the DEUTSCH connector you need and all 3 wires you need. Clip off the waffle connector, butt connect red wire to Aux, black to ground and wire tap yellow to fuse box.
JINO
JINO
Jino
Socal
2021 jlurd
This one has 4 wires. I'm trying to figure out which wire goes into my switch. I'm thinking this will take up 2 switches.
I'm guessing red is positive, black is ground, not sure what the yellow and white wires are for.
Jeep Wrangler JL Finally got my wiring for my lights 20240107_200634
Jeep Wrangler JL Finally got my wiring for my lights 20240107_200654
Jeep Wrangler JL Finally got my wiring for my lights 20240107_200728
ParadigmDawg
Greg
Fort Worth TX
Oh, in the picture it looks like there are 4 wires. Just temporarily connect red to power, black to ground and one at a time, power the yellow and white to see what it lights up. I would guess that the red powers high beam and white powers low beam. If that's the case, you can't power both at the same time without a specific relay. My LP6s are the same so I just didn't hook up the low beam.
JINO
JINO
Jino
Socal
2021 jlurd
I found this diagram. Seems white is the DRL/backlight. Yellow is dimmer, I think it's suppose to automatically dim the DRL when it starts getting dark out.
So I guess I'll use 1 switch for red (main) and another switch for white (DRL).
