Finally fixed my death wobble!!
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
I ordered the Dynatrac ball joint
Where did you get those?? I’m local to Dynatrac and I have not heard of ball joins that fit the JL axles. They only had them for the Jk last time I checked.
DexterJeeper
DexterJeeper
Ryan
Michigan
14 JKU Rubicon X, 19 JLU Rubicon, 23 JL392XR
DexterJeeper
DexterJeeper
Ryan
Michigan
I have all Synergy steering components and 37s and was having DW too. I installed the Dynatrac BJs a week ago and early testing indicates they solved my DW as well. I also did the RR knuckles and RCV shafts at the same time. I'll know for sure when I do a longer road trip soon.
And my Jeep only has about 13k miles on it.
Let me know how they work out for you. Crazy that the factory stuff wears out so quickly!
gato
New England
2021 JLUR
Lots of people don't understand the single and double adjuster setup Synergy uses and set it up wrong.
On the single adjust side the minimum threaded distance is the concern. As long as you are threaded in that far, or further, it will clamp correctly.
I've helped/installed many of these and once you understand how the adjusters work they really are not a big issue.
I hear you. But the root of the problem is still the fact that Synergy cheaped out and did not produce a wide version of their tie rod like every other manufacturer did. No one had issues with the Synergy tie rod on the JK. On the JLR lots of people had problems, including experience youtubers (you know who) who had to re-install it. Why? Because the length is too close to the limit on a Rubicon. Any system that is error-prone will be installed wrong. A good design preempts that.
What about the tie-rod clamp for the stabilizer relocation? If you keep your factory tie-rod the clamp is all the way closed and mine moved once already. Again it's cheaped out design.
I don't want to beat up on Synergy. I like their stuff. They were the first company with on-vehicle adjustable control arms and links - great innovation. But they cheaped out on the JL so far.
gato
New England
2021 JLUR
Also I live in MI so my knuckles were a huge pain to remove from the ball joints because of the corrosion. I broke a pickle fork and a ball joint separator doing it. I also had to heat and beat the crap out of the aluminum knuckles so I can see some Reids or Mojave steel knuckles in my future. ?
I already mde the decision that I'll change ball joints and Mopar iron knuckles together for that reason. On another thread I was asking question to see if I should tackle the ball-joint replacement on my own. Your story is discouraging me from doing it. I live in New England salt city USA.
DexterJeeper
DexterJeeper
Ryan
Michigan
Knowing what I know now, I would say that I have enough confidence to do it myself again in the future. But it did take a lot of trial and error (mostly errors) since this was my first ball joint change. The thing that made the biggest difference for me is this HD adjustable pitman arm puller. Literally nothing else worked. It took me 4 trips to AutoZone to finally find a tool that did the trick for me. With this tool, a little bit of heat and slight hammering (with a small hammer) once you have good tension will make the joints pop. It's pretty loud and scary but it works beautifully. Good luck with your project!
DexterJeeper
DexterJeeper
Ryan
Michigan
One other thought I forgot to share. Once the knuckles came off, the ball joints themselves were a piece of cake to press out and back in. I ordered the $12 kit that Dynatrac offers and used a rented ball joint press from AutoZone. A long breaker bar is all you need to get the job done.
gato
New England
2021 JLUR
Thank you so much for taking the time to post this. Did you have any problem reinserting the passenger side axle through the FAD colar? Did you have to open up the FAD? (that is my other "fear").
DexterJeeper
DexterJeeper
Ryan
Michigan
I’ve learned so much from this forum so I'm glad I was able to give back a little! To answer your question, I did have trouble putting it back in without opening up the FAD because the coupler slides out of place once you remove the outer shaft so there's no way to get it back in without opening the FAD. This is the part that all the YouTube people don't show you! But don't worry, it's very easy. Take the skid off, unplug and take off the four 13mm bolts and you're good to go. Just remember to put something below to catch the little bit of oil that comes out and go easy when you remove the back of the FAD so you don't damage the gasket.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
If reusing the factory axle shafts, simply shift the t-case to 4h and the FAD motors shift fork will hold the coupler to where you'll feel the splines engage during reassembly. No need to remove the FAD motor unless you're also upgrading axle shafts.
Zandcwhite
Zach
Patterson, ca
2019 jlur
My local tire shop only charged me $200 to install my hd ball joints. Having done ball joints on previous Jeeps, that was a no brainer for me. Time is money, a couple hundred bucks to save me a half days work is totally reasonable.
entropy
Foothills of the San Gabriels
OF top 1% content creator
Opening up the FAD isnt bad. Taking off the C clip is easier with small pliers.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
The fact that people don't read/can't read is not Synergy's issue.
Again I've installed a bunch of these on a variety of JL's and zero issues if you follow the directions and get it setup close before bolting it on.
The tube length as it is is perfect as you install the single adjust side all the way in for the short axle; or install it out for a long axle.
The other solutions that have different length tubes are because they use a jam nut style end which is a whole other can of problems especially then it's steel into aluminum.
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
  • Like
Reactions: DrJ
