Fender Light Wiring Schematic/Diagram?
Sean K.
Sean
AZ
JLUR, TJ, 4Runner, Cummins tow rig, 2 Tube Frame Buggies, Lotus SC Elise, Mazda 3, RAV4 Hybrid
American Jeeper
Jeremy
Kansas
2019 JLUR
Software & cloud services
Did you ever figure this out? I am thinking of wiring aftermarket halos to my DRL’s. It would be cool if they come on and can be turned off with the DRL’s in UConnect.
4xnaz
Tim
Phoenix, AZ
2018 JLU Rubicon
Does anyone have a wiring schematic for the front fenders' DRL/Sidemarker/Turn Signal?
It's a 5 wire connector going to the DRL/Turns and a 2 wire on the sidemarker. The side marker is easy....white is power, black is ground.
On the 5 wire to the DRL/Turns...the white and green striped wire powers the turn signal. The white with brown stripe wire powers the DRL through any lighting function, be it parking lights, DRLs or actual lights. Black is ground.
No idea what the other two wires are for. I'm guessing it has to do with the DRL shutting off while the turn signal is blinking for one of the wires, but it may be that they are grounds for separate loops/functions. I couldn't get either to light my circuit tester with any combination of lights on/off.
I'm no electrical expert....so if anyone knows what the other wires are for, I'd appreciate the insight.
FOLLOWING....
mwilk012
2018 Ocean Blue JLU Rubicon
Service
What an odd old thread to drag up. Looks like Sean had some errors in his testing, the white/brown is just the parking lamp.
The link to the drawing you just posted by the way is only for the LED fenders, but its still accurate as far as this discussion goes. Hard to tell what OP has because there were no pictures, and every wire in them is the same except for the side markers.
JQ4life
Palm Harbor Florida
2020 Wrangler
JQ4life
Palm Harbor Florida
2020 Wrangler
Sean K - just a note to thank you for breaking down the color code for the driving lights. I just installed a new grill on my JL and your post was a bug help. Thank you
