Failing Alternator
ImAJeepskate
Grant
Minnesota
2018 Jeep Wrangler Unlimited Sport (JLU)
Was almost done with a 300 mi road trip and noticed that my voltage was only around 12.8v while doing 67 mph in 5th gear. It would never go over 13v unless I was off the throttle engine breaking (manual transmission). I assume this is because of less draw from the ignition. But shouldn't the alternator be at 14v or at least above 13v? Also I have the standard (non-high output) alternator.
Jeep Wrangler JL Failing Alternator 20190529_183927
LincolnSixAlpha
Arizona
I agree with the other two comments. Also worth noting that if your alternator was failing, your vehicle would soon stop running as the batteries, on their own, do not have enough juice to fire the fuel injectors, among all the other electrical needs of the vehicle.
Also, I own/drive BMW motorcycles, and have so for years. They integrate well with Garmin rebranded BMW Navigator GPS units. There's an information page that gives you particular stats such as current fuel consumption, range to empty, as well as a voltmeter. Like the Jeep, the alternator output is a little higher on startup, until the battery is topped off, then drops to low-mid 12's. I had a battery at one point with a bad cell, the voltage output was always in the 14's, which clued me into the issue.
ImAJeepskate
ImAJeepskate
Grant
Minnesota
Appreciate the explanation!
smokinjeep
jim
MN
2019 JL on order
I dont know a thing about alternators, volts, amps etc but agree with the other three because i want to sound like I know something.
LincolnSixAlpha
Arizona
Well, to be honest, I'm no electrician either, I just found out the hard way with a few of my daughter's vehicles in which suffered battery, AND alternator problems. Anyhow, cars today are so, so much more complicated than they were many years ago. I remember driving home in my 74 Subaru in the mid 80's on just the alternator. The battery had died. Lights would go dim when I came to stop signs, then bright again as the engine speed increased.
melendez69
Marc
Waxhaw NC
...huh?
My JL always cranks up at 14.2v, & I've taken her on a few 200+ mile trips this year. By the time I got home each time, it would drop down to about 13v. I used to have voltage anxiety, but I've learned what the gents here are saying. Perfectly normal.
But I still keep a trickle charger.
Shenanigans
NorCal
JLU Rubi
Mine consistently runs at 14.2 to 14.3 volts.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
So does mine or higher. Makes me think one of the batteries is on the way out. When i first got the jeep it would fluctuate as its supposed to. Now its a constant 14.2-14.7
Shenanigans
NorCal
JLU Rubi
Charging systems are designed to be around 14 volts while the motor is running. A healthy battery that isn’t being charged by an alternator should be around 12.6 volts. I’ve had all sorts of charging systems as I was a huge stereo guy. Dual alternators, isolated 12 volt systems with six 6 volt batteries, multiple 12 volt batteries, etc.... I was a 12 volt freak for a very long time.
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Yeah when i check resting voltage on my display before i start it up in the morning its at 12.3-12.4 volts
Markham
Maine
2020 Sahara High Altitude
I have an auto, but when I’m on the throttle the voltage drops, when I coast it goes back up.
Token
Toronto
2019 JLUR
Go WOT.
You’ll see it go up again as your A/C clutch disengages.
