ESS not working, battery charging on 2019 2.0 e torque.
scottijohn63
Santa Barbara, ca
19' Sarah Mopar Lift 35's 4.88 , C8 Stingray HTC
I only have one battery which I replaced three months ago. With the old battery I was getting this message. I replaced the battery and everything was working fine, but about two weeks ago I started to get this message again. Any ideas why? Thanks in advance!
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
I think if you have the e torque system you have a larger battery system in the wall of the cabin near the back or since it 2019 model it may be underneath near the back of the jeep....you should have that system checked.
scottijohn63
scottijohn63
Santa Barbara, ca
Thanks so much!
Beachcomber72
2022 JLU High Tide
What is the exact specific message you are seeing?
Beachcomber72
2022 JLU High Tide
ESS disabled battery charging.
Are you driving short commutes or long commutes daily? The Etorque battery gets recharged by regenerative braking. If it comes down to it. If I’m correct. You may want to plan a 2 hour road trip with dozens of slowdowns and stops and then straight shots above 55 for long periods to see if the issue doesn’t resolve itself.
@Rhinebeck01 may be able to shed more knowledge on the matter.
scottijohn63
scottijohn63
Santa Barbara, ca
Thanks for the advise. I don't think that is it since I have taken a fairly long trip in the mountains where I have had to break quite a bit.
scottijohn63
scottijohn63
Santa Barbara, ca
I just had the new battery checked. It was fine, but my alternator did not pass the test! Voltage gauge reads between 13.9 and 14 volts. Any known issues with the alternators on 2019 2.0 etorque? Should I go ahead and replace the alternator? Any idea on cost? How hard would it be to do myself? Thanks so much!
scottijohn63
scottijohn63
Santa Barbara, ca
After reading some threads on the IBS I decided to reset the sensor by disconnect the battery. The ESS is now working. Battery voltage is showing at 14.2. I’ll update the post if this doesn’t turnout to be a permanent solution!
Tool Guy
So Cal
2019 JLUR, 2020 BMW Z4, 2021 Tacoma, 2022 X3 M40i
Glad you got it sorted. BTW that message has nothing to do with the eTorque battery, only the 12 volt starting battery as you discovered.
scottijohn63
scottijohn63
Santa Barbara, ca
Turns out resetting the IBS was only a temporary solution. I am back where I started.
