- Andy
- Nov 19, 2019
- SanFrancisco
- JL Wrangler
- Banned
- #31
Biases: I'm one of the few who doesn't have much issue with the ESS system. I do though trickle charge when parked at home and need to for ESS to engage when driving. This said, I completely get that people don't like being thrown a design that concerns them as it regards the additional wear and tear that cranking an engine has on the engine, starter and other components. Sure, that wear and tear is minimal compared to our "father's Oldsmobile," and the design incorporates so called heavy duty components, but "moving parts are subject to wear and tear."The way I look at it is that there is undue preoccupation with the "ESS factor". The Engine Stop Start function is straightforward; the engine stops and the engine starts.
This said, you're right...and the end of the day it's just (another form of) cranking and shutting down an ICE.
Sure--no questioning that with the 3.6L factory design, power draw, with no alternator to replenish the loss given a resting engine, drains the starter battery, but technically that starter battery might be considered the ESS/Aux battery, not the main battery. Regardless, the drain is lessened by the fact that both batteries are connected in parallel at rest, each contributing to the vehicle's resting power draw--not that you said otherwise---not that you're anything but correct.The complication is introduced by the insistence for drawing power while the engine is off under the premise that the practice can be exercised without impacting the effectiveness of the starter battery.
Which battery is the cranking battery kind of depends on how you look at it. I say this because cold crank operation tests the ESS/Aux battery--as you probably know--and then that test successfully past, brings in the main battery in parallel to allow both batteries (yes, primarily the main one) to effect the crank. 3.6L's can start solely with an ESS/Aux battery, or as Jerry has shown us, with some wiring changes that make the 3.6L "think" its checking/tapping the ESS/Aux battery. And sure, model year 2019 3.6L JLs and beyond, or flashed 2018's can crank with either battery and not be stranded if the ESS/Aux battery fails its pre crank test.
I agree. Question though...do you say this for reasons other than 1) moving energy takes energy, and 2) with dissimilar batteries and a design that ties the batteries to a particular function, either battery can be a parasitic drain on the other when connected in parallel, which for the 3.6L is all the time but for a second at cold crank and ESS events--especially when parked?Any system that ties two dissimilar batteries, or two batteries tied together that are tasked to different use is doomed to present troublesome experiences.
I think you ideally would opt for one big battery and in lieu of that 2 or more identical batteries in parallel, with no particular 3.6L task assigned to any one battery, but all batteries working together to effect all energy draw tasks. Is that about right?Adding the ability to disconnect the Jeep's two OEM battery scheme seems like a good idea. Utilizing the additional switching to reconnect the parallel connection may seem to offer a quick boost for the starting system, and it may seem like a quick and easy solution, but it is not the most efficient use of the potential energy you are transporting.
Whereas that might be more efficient, doesn't the ability to separate the batteries (permanently, temporarily, or by logic (i.e. Geneses)) add additional fault tolerance?
I hear this, but couldn't the ESS/Aux battery, properly charged, solely energize the crank, and then, with the alternator running, reconnect the batteries in parallel (immediately or at some point thereafter when voltages of the two batteries are, say, equalized) so replenishment of the main battery is a task that ultimately the alternator does, as parasitic draw from the main battery to the ESS/Aux is minimized by the main and ESS/Aux batteries getting replenish from the alternator?The result of disconnecting the auxiliary battery and temporarily reconnecting it as a booster is that some of the downsides of running two dissimilar batteries are retained. The behavioral relationship between the two batteries is reversed. The aux battery will now sacrifice itself to charge the primary battery, where as in the unmodified system the primary battery tends to sacrifice itself to support the auxiliary battery. Regardless, of the configuration, the parallel circuit of dissimilar batteries will result in a system where battery life cycles are being squandered to charge batteries.
I respect that; it may even *for you* prove the optimal situation. Heck, other vehicles run ESS with 1 battery. But for many JL owners, who not only have optional gear that pulls power, but that may do so with the engine off, I'd think that the ability to separate batteries may make sense in increasing the chances for successful crank when in the middle of some overland adventure. Mind you, FCA didn't design it that way...but....For my part, when my auxiliary battery ages, I will remove it and send it to the core yard. I do not intend to replace it. It is unnecessary and I do not see any benefit to using it.
It's almost as if--if I hear you correctly, that acquiring the Geneses double battery tray and identical Geneses "group" rated batteries, and hooking them up parallel permanently, sucking up the 6 ESS events per crank byproduct, sounds appealing to you as well.
I am not debating with you....I'm just discussing pros and cons of various approaches.
