bmpcamry09
- Brad
- Feb 13, 2026
- New Athens, IL
- 2025 JLU Sport S 3.6 8AT
You’re lucky if you’ve got 87 in your 2.0 and no knock. What about wide open throttle? Which knock retard are you watching? There are 3, short term, long term, and fuel. Short term and fuel are the ones for what is currently happening. Long term is the learned value applied consistently.I've done some real-time monitoring, but so far in somewhat limited circumstances. I get absolutely 0 timing pull during my hilly commute at ambient temps of 70 degrees or lower. I occasionally see a half to one and a half degrees when temps are a little warmer. I get 0 under light acceleration on the freeway. I'll soon see how the Summer and longer trips go.
I was making more reference to actual spark advance. As soon as throttle is tipped in I was seeing negative spark timing itself.
