Enabling auto dim mirror in BCM
Toxiclows
Christopher
2020 Willy’s jl
Thanks for that information. I did not know there is a difference in the ‘18 vs ‘19 radios.
I tried a used 2018 8.4 UAQ made by Panasonic I got off eBay in my 2018 Sport S which came factory with 7” and Apline audio and dual climate control. Had to send it back as I ahas a green screen backup camera. Everything else expect Guardian worked which I did not expect.
I ordered a NEW 8.4 UAQ from Mopar wholesaler which will be delivered this Friday. Crossing my fingers!
I was talking with a Jeep technician on Facebook that said the units are self learning which reinforces your point that the 2019 units read the BCM to enable the features. This gives me hope.
thanks again for your response.
Do you or anyone else have any insight on this green screen. I bought a UAS ( no nav) from an 18 ram to put in my 2020 jl. mounting was a little different. and it was a little big to fit into the dash. but nothing a little dremel could not fix. .
anyway.... I have the green backup screen as well. the fellow I bought it off of had mentioned that it was green for him. also when he had it in his wrangler. we were thinking it was a different camera type used on the rams. but i would like to know if there is a way to work around this, ,
Toxiclows
Christopher
2020 Willy’s jl
I will agree with this. . .as a jeep tech myself. we dont get trained in the inner workings of the radios as far as swapping them around goes. . . however the used one (8.4) I bought. when i fist plugged it in. off road pages was there. and after a few reboots. it went away. . . . it never did actually work. but there was an icon for it as well as you could click on it and it would attempt to load for a few seconds. and then just flash back to the home screen. now it just disappeared. . Im thinking this is more a bcm. function rather then the radio
WarlockLord
Tony
2019 Jeep Wrangler Unlimited Sahara
This is correct. The flag for off road pages is stored in the BCM and can be enabled with a Tazer.
WarlockLord
Tony
You need a camera from a 2018 JL, most likely. There is a difference in the part numbers for the 2018 and the 2019-2021.
Toxiclows
Christopher
2020 Willy’s jl
def looking into .. .thanks.
WarlockLord
Tony
Just to try to be a little more helpful..... there is a TSB regarding replacing the rear camera if your auto keeps dropping out in 2 second intervals and the rear camera screen is blue with a message that camera system is unavailable.
In that TSB is the part number for the two different cameras.
UPDATE: I found the TSB in my camera roll. The 18 p/n is 68288397AC. The 19 p/n is 68414411AA.
JSFoster75
Bluff City, TN
I test drove a Jeep or two with the 7" screens, but searched for one with the 8.4 UConnect with the other options I wanted... I was afraid of headaches like this if I tried to upgrade it. I can't imagine trying to install an aftermarket system although Crutchfield does a great job helping match up what is needed for a complete system replacement.
Toxiclows
Christopher
2020 Willy’s jl
I looked it up in dealer connect the 2020 part number is 68452959ab. And the 2018 part number is 68288397 AC
Might be onto something here don’t know if I want to drop 100 bucks on the camera just to try it but it be nice to know if anybody else has had this problem I’ll have to post a picture of the screen it’s not your typical green screen I still have a full view everything is just green like you’re looking through night vision binoculars
