Emergency/ Trail Toolkit list?
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
How many D rings should I be purchasing? Not sure how many mount points there are on the JL with stock bumpers...
Also, any specific recommendations on D rings? I’m thinking I’ll also plan to run with isolators.
Similar questions for tow straps. Recommendations on length? Any special considerations to consider? Do others agree with the recommendation above for a kinetic strap/something with give in it? That surprised me, though I of course know nothing about them.
If you're running stock bumpers, plastic or steel, you will need zero clevis shackles (or d-ring as they're sometimes called as there are no shackle tabs to attach them to. If you have a hitch and pick up a Factor 55 hitchlink or something similar maybe one d-ring. If or when you upgrade bumpers to something with something from the aftermarket that has shack tabs, then you'll want to pick up some d-rings. Personally I never saw a point to running d-ring unless I'm wheeling so I never needed isolators. The two problems I see with running around with them in the bumpers all the times is one the pins will become loose and you might end up losing one (it happened to a buddy on his F250) or if you live in the midwest they'll rust to hell.
You don't want any sort of top strap, chain or anything with metal hooks. You want a specific recovery rated strap.
aug0211
Ohio
JLUR 4xe
Thank you for the help!
Can you clarify the above portion? I didn’t follow it - did you mean to say I will *not* need...
JeepRubiCan
JeepRubiCan
Case
Denver, CO
2018 JL Rubicon
Check out the Rhino straps and D-rings!! Amazing quality
kkuntz01
Kevin
Mount Juliet, TN
I meant it to read that way, if you’re running stock bumpers you will need zero d rings, as in, not need any.
aug0211
Ohio
JLUR 4xe
I’d suggest ditching the tow strap and getting a kinetic recovery strap (nothing with metal hooks) 25-30ft. You want a strap that has some elasticity in a recovery situation that will stretch and “snap” back to aid in pulling the stuck vehicle free.
Thanks for sharing this. I just started doing some frs
Doh! That makes sense. My bad. Thank you!
Dubeau9005
Keith
Ottawa
2018 Jeep Wrangler JLU Sport S, 2010 GMC Sierra 1500
What type of fire extinguisher does everyone recommend to carry around? I am in Canada so need to make sure the type I get is also compatible in the winter (not sure if that’s even an issue).
BostonBilly
Billy
Mass
2015 JKU
ABC is the type I carry. It covers all types
aug0211
Ohio
JLUR 4xe
I’m also looking for info on a fire extinguisher. I’ve read that some types clean up easier than others. Any specific brand/model recommendations?
NYC_Bobby
Bobby
NYC
2018 JL Rubicon, 2018 JL MOAB, 2016 Renegade Trailhawk
aug0211
Ohio
JLUR 4xe
Yellow109r
Michael
Oklahoma
2018 Jeep Rubicon JLUR, Bright White
Aircraft Industrial Engineer for the DoD
Here's my working doc. The left tab is the most distilled down. It's still a work in progress but might provide some stimulation for your little grey cells. Most of the info was pulled off the JK Forum when I was thinking of getting a JK. It's part bug-out, part camping, part emergency kit.
Awesome List, thanks for sharing
kogar
JD
Cedar Park, TX
JLUR EcoDiesel
I carry a bunch of goodies for recovery in my Jeep, including a large toolkit/socket set. The problem is that the toolkit is pretty heavy and has WAY too many items. I’m curious if anybody has created a list of tools you should bring on the trail (ie - 18mm socket for sway bar disconnects)?
kogar
JD
Cedar Park, TX
JLUR EcoDiesel
Cmon, folks. Nobody carries a toolkit for their jeep? . Off top of my head, you’d want:
Duct tape, bailing wire, 18mm socket, 40/50 torx, screwdriver, vise grips, crescent wrench, headlamp, dead blow hammer, work gloves. What else?
CypressWrangler
Jon
2018 Wrangler Sport S JLU
I will add some stuff I have. Zip ties, pry bar, full SAE and Metric socket set, small tarp, bungees, tape, screw drivers, knives, multi tool, flash light, magnetic flash light, 4 bottles of water, small first aide kit, 5 pack of shotgun shells, fire starter, few more survival items, salt and pepper.
In a separate bag I have my recovery items, links, straps, etc.
Jondrew
Bob
Central Fl
2018 Rubicon
