Anybody have a spare parts list for JL overland trip
Lorenc
Loren
Palm Desert
2019 JL Rubicon
Has anybody put together a recommended spare parts list yet to carry in the JL on overland trips?
Does anybody know if they changed the plastic piece that frequently broke in the JK Transfer case linkage?
Loren
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
I haven't seen a list yet. I've started putting together a list of stuff that I might want to have as spares for a long weekend trip offroad. I have also wondered if the transfer case shifter bushing is going to be an issue.
Multimeter
Fuses 10a, 20a, 30a, 40a, 60a
10ft of 12-G Stranded wire
U-Joints
Tie Rod Ends
Serpentine Belt
Crankshaft Position Sensor
Front Brake Lines
Brake Fluid
Colby Emergency Valve Stems
ATP AT-205 RE-SEAL to stop leaks
Fuel Water Removal Additive (crappy gas at remote gas stations)
Radiator Hose Repair Kit (Maybe even Radiator Hoses)
Steering Drag Link End
JimLee
Jim
Too damn close to Death Valley
'19 JLU
I bought one of those master fuse bus bars (High amp fuse array), pop one of those and the whole thing is dead. Mopar part number: 68368853AA
Lorenc
Lorenc
Loren
Palm Desert
2019 JL Rubicon
So I’ve been working on my Offroad kit list, here is what I have so far
  • Multimeter
  • OBD Code Reader
  • Fluids
    • 5-20 engine oil
    • Mopar electric power steering fluid
    • 140 gear oil
    • Gasket sealer
    • JB Weld
    • DOT 3 brake fluid
  • Rescue Tape
  • Electrical Tape
  • Duct tape
  • Electrical connectors
  • Fuse assortment
  • 4 hose clamps
  • Extra pair Red Neck Ram hydraulic hoses
  • Bag of zip ties
  • Extra bottle jack handle for welding brace
  • ReadyWelder II with .035” flux core wire. Leather helmet, vice grip, brush, slag hammer, and gloves
  • Bag of Assorted Grade 8 Bolts, washers, and nuts. Small nuts and bolts
  • Spare Trans case linkage bushings for JK Friends
  • Tire patch kit
  • Colby valve stem repair kit
  • Battery jumper
  • Universal brake line
  • 60# of tools
It’s getting heavy, but what am I missing?
Loren
Lorenc
Lorenc
Loren
Palm Desert
2019 JL Rubicon
I’m not sure what this is? Can you explain what it does?
JimLee
Jim
'19 JLU
Just a little follow-up post in regard to this...
Turns out this (thing with 6 nuts) :
Turns out..... this is Mopar part# 68368853AA. (Costs $60+-)
It is a row of high amp fuses that are part of the PDC on the Jeep Wrangler JL. This Is a replaceable / separate component. Again it is replaceable, so keep this in mind if a service dept. says you need to replace the whole $600+ PDC center because any of these fuses are say fried.
You remove the 6 nuts and off will come this part and it is very easily replaced. If you look at the pic below of it, you will see that the missing middle nut, is absolutely of no consequence.
Note, Mopar part# 68368853AA is a solid, one piece unit. The individual fuses, are attached to the metal plate. Each fuse is numbered and labeled as to amperage.
@WranglerMan
@everyone
High AMP fuses. If the wrong one pops you will be stranded without the ability to start your vehicle. You have to replace the whole bank as it is a 1 piece unit. There's a long thread here on the forums about the dreaded ESS system and how it can leave you without the ability to restart your vehicle if the aux battery is dead, both batteries connect power through this fuse bar. If you pop one you have an electrical problem somewhere, if you are able to sort out the electrical issue but the fuse is popped you are still screwed until you replace it.
Maverick909
Inland Empire
www.instagram.com
your missing on board air Loren for filling tires
Lorenc
Lorenc
Loren
Palm Desert
2019 JL Rubicon
Maverick909
Inland Empire
www.instagram.com
I have both an Arb twin on board as well as a 10# CO2 tank...both are mounted...
very nice. ive been debating that setup my self. i plan on a rear ARB air locker in the next year or so. but from what i hear the CO2 is the way to go!
Lorenc
Lorenc
Loren
Palm Desert
2019 JL Rubicon
I love the Co2, I can fill my 40s from 9 to 35# in a little over 30 seconds, but the tank will only do it twice, this the Arb is a dependable source.
Maverick909
Inland Empire
www.instagram.com
thanks for the heads up. ill look into geting both. probably start with the compressor though.
