Electrical, radio issues
TomPro
Tom
Paxton Il
2018 Wrangler JL
2018 Wrangler jL 2.0 What’s the deal with these electrical issues?? Sometimes the radio powers on, connects to my phone but the display is blank. Only happens occasionally. Now, new issue I get in and try to start it and it says key fob not detected. Try it again and it says to push the start button with the fob to start. Anyone else have these issues? What’s the deal?
PocketsEmptied
NC
'08 JKUR, '21 JLUR
Not sure on the first one but I'd check your aux and main batteries to make sure they're good, if you haven't changed them out yet 3 years seems to be around the average lifespan of them. For the FOB sounds like a battery issue as well, that's easy enough to change out.
TomPro
TomPro
Tom
Paxton Il
2018 Wrangler JL
Sounds like what I’m hearing. I just had to put a new battery in her a couple weeks ago. Still having issues with the radio. I’ll change and battery in the fob and try it
Thanks
falcon241073
Trey
Byhalia, MS
2021 JLUR
Thanks
Did you replace both batteries?
Heimkehr
Pennsylvania
2021 JLU 2.0T
My default M.O. when any electrical/electronic issue first rears its head is to confirm the age of the batter(ies) in the vehicle and the key fob. Replacing one, or both, has in the past resolved at least some of the issues.
There will always be examples of electrical problems that are indeed problems that require investigation and fixing. Battery health is an easy first approach to eliminate that variable.
wrightpsu
Tony
Greenville SC
2021 Wrangler JL
I am having the same issue. Did you every resolve the problem?
