Electrical Issues possibly related to battery
sumaznguy210
Sam
San Antonio
2021 JLUR
Just wanted to check in here and see if anybody has experienced my issues, I've tried searching the forums but haven't had any luck.
A few months ago I started to have issues with 21 JLUR 2.0T, my ESS started to act up and I had the typical service start/stop system. All of the sudden the issue went away and when I mentioned it to the dealership they were unable to replicate the issue. Fast forward to this past week I started to have the same issue and then a few days later my passenger headlight and tail light stopped working. The brake and turn signal on the tail light works, however my headlight has no functionality.
I did the aux battery bypass after a bit more research and have also swapped out the exterior light fuses. My hunch was that my main battery is drained, however when I took it to an auto store today, I was told it was still good and just needed a charge. Does anybody have any idea what it is? Thanks in advance!
running_man
Andy
2019 Rubicon JLU, 2003 BMW Z4, 2012 Lexus ES350
While I didn't experience any start/stop issues, when I had battery issues and took it to Autozone to be checked, initially they told me it was fine and just needed charged....fast forward 3 days and battery issues again. Took it back to Autozone and a different person told me that the battery, in fact, was bad. Not sure how old your current battery is or if it's AGM or not, but I'd invest in a new battery and get the AGM H7 with 850 CCA, should last longer and be better than the H6....
