electrical issues, dtc codes lost powering steering, stuck on acc mode
vlbyorick
victoria
york
jl wrangler sport 2 door
Jeep Wrangler JL electrical issues, dtc codes lost powering steering, stuck on acc mode IMG_9887
@JeepCares 2019 wrangler jl sport 2 door manual. 68,000miles. started with flashing abs light 2months ago with then start stop not working( given i replaced the aux battery 3 months before this happened) delearship said both batteries needed replaced so i did that. moving forward 2 weeks agos i got all these codes .ran the scanner because i got my dash lit up with every warning you can possibly imagine. every time it happened it wouldnt let me turn it over to off but wound turn over to acc.while making a weird noise(video attached) .finally it will turn over to off…one day on the turnpike the jeep did this but this time i lost my
power steering. i called the dealership and they now have the jeep and i have a rental. i also found a sensor with a white wire hanging . any thoughts . i bought the jeep brand new .what a sad story for me
Jeep Wrangler JL electrical issues, dtc codes lost powering steering, stuck on acc mode IMG_9819
speedymart
mephis
2021 jl
Clear everything and when the issue occurs see what is active. The connector you linked *appears* to be for one of the oxygen sensors, but I can't say for sure from the angle. There aren't any codes indicating it either. It definitely seems there's an issue with the electric vacuum pump/brake pedal sensor based on your symptoms and DTCs, but there's a lot of extra stuff in there that's probably unrelated.
Clear codes, drive until issue happens, and scan the vehicle then. Also, are you driving with a Tazer or anything plugged into the diagnostic port?
vlbyorick
vlbyorick
victoria
york
no tazer nothing plugged in port…ill pass this on to the dealership when they let me know what they found. ill we keep this forum updated
vlbyorick
vlbyorick
victoria
york
@JeepCares ….dealership just called me over 50 codes for communication. they cleared the codes and put so far 100miles on the jeep without being about to yet produce the flashing dashboard .no codes have popped up yet after clearing it. they are going to continue to put miles on it till the codes pop up again. what a nightmare
Jtcal78
Josh
Oregon
2020 Jeep wrangler unlimited Willys
I have this same issue, the same as thousands of Jeep owners. Pass on the info when you find out. I'm about to name mine BOAT. Bust Out Another Thousand.
vlbyorick
vlbyorick
victoria
york
report it to the NHTSA.gov . I reported my issue last night and will be calling jeep cares for a advisor
Jtcal78
Josh
Oregon
What's that going to do? They are ran by the big 3. This won't help anyone until people are killed when their power steering quites and the roll over.
vlbyorick
vlbyorick
victoria
york
dealership just called me and is making me return the rental and releasing the wrangler saying they couldnt replicate the problem…. 60codes and just giving me the jeep back like nothing
Jtcal78
Josh
Oregon
I'm sorry to hear that. The DLR is a horrible shop for repairs. Kids that change oil and do simple fixes. Try your CanBus Block behind the glove box. Green and white blocks. Check every inch of wiring you can find. Check your batteries after it sits. Just check and replace what you can. And find a actual technician. I feel your pain brother. But not giving up.
vlbyorick
vlbyorick
victoria
york
they checked all the connectors pulled every pin out. made sure all the sensors and connectors were corrosion free.they called Chrysler and they said it could be multiple things . dealership said they hope it was just a loose connector that they accidently fixed while checking all them.heres the dtc
Jeep Wrangler JL electrical issues, dtc codes lost powering steering, stuck on acc mode IMG_9998
Jeep Wrangler JL electrical issues, dtc codes lost powering steering, stuck on acc mode IMG_9999
Jtcal78
Josh
Oregon
I had all of those also. But after replacing the canbus blocks and checking the connectors. (To see if the glove box pulled on the wires) The only messages I have is power steering. But my power steering is still working. So I started out cheap and will take it to a actual tech soon once I'm sure it's only power steering. Waiting to make sure these codes don't change and no new ones pop up.
geem03
Gary
New Brunswick Canada
2019 Jeep Wrangler Sport
RN/ Firefighter
Similar issues and replaced batteries, seated all fuses, cleaned and tightened all grounds that I could find, checked wiring harness, replaced CANBUS, disconnected radio, HVAC, doors, tazer and all aftermarket accessories to rule out short, and in the end, it was the power steering pump causing all my problems. I replaced it and so far, no other issues.
If you disconnect the bottom plug on the pump (as there are two, one sits over the other) and if it clears all your codes except the power steering pump, then most likely that is your culprit.
this was my experience....
vlbyorick
vlbyorick
victoria
york
the dealership cleared the codes and drove it over 300miles after checking and reconnecting all the sensors and connectors, grounds etc… nothing has come back on ,its only been day 2 since i got the jeep back ..ill keep everyone updated as the days pass
vlbyorick
vlbyorick
victoria
york
ess light came on today while driving cruise control… then windshield wipers came on by themselves and wouldnt stop till i powered off the jeep. going back to the dealership tomorrow @JeepCares
Jtcal78
Josh
Oregon
Did you change out your Can bus blocks yet. Do that. It's a simple replacement. Because if it's not a Can bus it could be a spring clock collar in your steering column. But with everything else happening, I would do the Can bus behind the glove box.
