E-Torque Motor-Generator Unit Oil?
waypoint
NJ
2021 Sahara Unlimited; 2017 Sport-S Unlimited
New '21 Sahara Unlimited with 3.6L E-Torque and auto transmission, I'm at 2100 miles and reading the owner's manual. In the Fluid Capacities section it lists the "3.6L Motor Generator Unit" as having a 1.9 quart capacity. There is no listed oil change interval or oil specification for it. Is it a sealed unit, just run to failure and hope it dies within warranty?
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Is that coolant not oil? It is liquid cooled.
Gregj
This is correct. It is on page 510 of the owners manual.
3.6L Motor Generator Unit (MGU) (Mopar Antifreeze/Engine Coolant 10 Year/150,000 Mile Formula or equivalent) : 1.9 Quarts
waypoint
NJ
Thanks, that makes sense. Really enjoying the Jeep thus far, after selling my '80 CJ5 back in 1990.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
the question is which fluid I will need to use , for number 9 and 5 we know its antifreeze coolant but number 7 (poer pack unit ) which liquid ???
I'm assuming the same OAT MS.90032 but really not 100% sure.
However, I just noticed my '23 manual states 2.2 quart capacity for the MGU (instead of 1.9) and 3.3 quarts for the PPU (instead of the prior 2.5 spec).
mwilk012
Service
What numbers are you talking about?
AFD
Northeastern US
Number 7 in the pic
I'm almost certain that both the MGU and PPU use the exact same Mopar OAT MS.90032 antifreeze coolant. On page #493 and 494 of the 2018 Wrangler owner's manual (with both 2.0T eTorque and 3.6L eTorque specs) it distinctly lists "battery coolant" separately from the MGU coolant. Since the generator/MGU is listed and no other batteries on the vehicle are liquid-cooled, the power pack unit (PPU) should be the battery mentioned here.
The OEM part number for the coolant should be 68163849AB for 10-year 50/50 premixed.
Jeep Wrangler JL E-Torque Motor-Generator Unit Oil? Image1
https://cdn.dealereprocess.org/cdn/servicemanuals/jeep/2018-wrangler.pdf
Mazin961
Mazin
Oman
Jeep JL 2021 V6 E-torque
Okaay i see , so you mean 5 & 7 & 9 all of them are using the same coolant fluid I guess?
Jeep Wrangler JL E-Torque Motor-Generator Unit Oil? IMG_1750
Theweda123
Iowa
2020 Jeep Wrangler Sarhara JL
Has anyone had trouble getting the caps off #7 and #9 (see pic) to add more fluid? Ive tried pushing and turning and all it does is click.
Jeep Wrangler JL E-Torque Motor-Generator Unit Oil? IMG_5119
iGeeker
Scottsdale AZ
18 JLU Sahara
There is a small slot on each black caps. Align the slot to another slot underneath. Then put a flat head screw driver into slot, turn the cap
dstrahm
Doug
I wonder how many owners (and service persons) put washer fluid in those coolant reservoirs before they changed those cap designs. 🤣🤣
