Driver side Upper control arm heat shield impossible to remove
tengg2001
JLUR
Hi all,
I’m installing a lift kit in my JL 2 door 3.6 e-torque today, and I found it impossible to remove the driver side front UCA heat shield. There are 3 foil wrapped cable above the heat shield, and completely blocked the upper bolt.
I have a feeling that the three cables related to etorque system. wondering if anyone has experience of this? How do we handle the UCA body mount?
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
If II remember correctly I just removed what bolts could be removed and bent it out of the way. Then bent it back and bolted it back in. It's just a heat shield, doesn't need to be perfect.
XxsullyxX123
Somers, NY
2020 JLU Rubicon Recon, 2020 Honda Pilot Touring
on my 2.0 etorque i had an issue too with one of the sides. just bent it out of the way same as reinen.
