Upper control arm length to castor degrees
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
Anyone know what delta length translates into a degree of castor shift with the upper control arms? Trying to short cut the trial and a little.
meaning 1/16 or 1/8 inch = x degree more in castor.
Thanks in advance.
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
On my EVO adjustable upper arms, if I recall correctly, it was about 3 turns equaled about 1 degree in castor change. I don't recall the thread pitch, but I'm guessing close to 1/16". I made a few changes, so I could be a little off in my memory, but somewhere around there.
If you have adjustable upper control arms, it's real easy to make a change, then check the castor.
AnnDee4444
'18 JLR 2.0
Thanks in advance.
FWIW: shortening the UCA 0.25" should roughly equal the same caster change as lengthening the LCA 0.25". Your ride height influences caster as well, and a 0.25" change will not result in a consistent X degree of caster change.
Here are some 24" vs 24.25" LCA comparisons I have collected on this forum. The important difference is that the 0.25" length change is roughly equal to 1.25 degrees of caster change at Rubicon height.
Martindfletcher
Martindfletcher
Martin
San Diego
Thanks
I want .75-1 deg. So I will subtract an 1/8th or 3/16th and I should be good.
