Door hinges - grease?
JLJS74
near Chicago
Rubicon 4DR JL
Took the doors off my JLUR this past weekend, was pleasantly surprised with how easy the process was and obviously how fun it is to drive without them. Before I put them back on (supposed to rain here all week), I noticed that the inside of the hinge that’s part of the car frame seemed dry - I was expecting it to have a thick grease inside. So my question, should I add grease before putting the doors back or is that how its supposed to be?
OldGuyNewJeep
Don
CT
Normal. There are plastic bushings in the hinges. You can upgrade to Derlin bushings when/if stock ones ever wear out.
Jeepznthingz
Under a rock
2021 JLURXR Tuscadero, 2023 JLURXR Reign
That’s good to know...I was going to grease the hinges. Glad read this first.
RichD
Rich
Boston
2018 Sport S
Token
Toronto
2019 JLUR
Just throw a dab of anti-seize on the bolt threads before putting them back in.
That way they come out next time.
And of course you'll have some on your elbow, the dog's tail, and the upstairs bathroom... Because as soon as you open that stuff, it gets everywhere!
mgroeger
Southern UT
2021 JLUR 2.0T
I don't know anyone who bolts those bolts back in.
OldGuyNewJeep
Don
CT
mgroeger
Southern UT
2021 JLUR 2.0T
Let me introduce myself. :)
Why do I do it? Because I’m anal.
I used to be anal, owning a 2004 LJ and 2018 JL and off roading them cured me of that REAL quick. :)
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Greasing an exposed joint like the door hinges will cause dust and dirt accumulation in the hinge, which may then lead to premature failure. The bushing is a wear part and replaceable for a reason.
LowCountry
allen
Savannah Ga
2018 Billet Sport
Just replaced my hinge bushings with the delrin plastic ones. The stock bushings are metal, they are swaged on both ends so you have to tap the edges in with a flat head screwdriver before you can drive them out
mlebofsky
Denver, CO
2019 JL Rubicon softtop
Director, DoD
I'm thinking about just the opposite.
I will be removing the doors in a few hours, and since I'm used to my JK style doors, the limiters are not a requirement. It would be nice if I could find a tighter fitting hinge bushing so the doors didn't swing so easily.... No need for this new limiter hardware if the doors didn't flop around. Maybe?
