DOOR HINGE PAINT PROTECTION
Status
Not open for further replies.
rob28
Rob
Canada
JL 2dr Willys. 2021.
$15 shipping to Ontario? Is that correct?
Almost doubles the cost of these.
Warpath
St. Louis
2019 Wrangler 2.0T JLR 2-Door, 2020 GT500
Ormond Beach, Florida
Retired at 55 ..
Your Canadian, you know the drill. Canadians I know, one of their biggest gripes is cost of shipping from the US to Canada.
Blame Canada...
drock317
Derek
Indianapolis, IN
2018 JLUS - Ocean Blue
Order placed today. Thanks for the discount code to help off set the shipping charges. hoping I can install these without screwing up :)
AggieJeepGuy
NW AR
2018 JLUR (replaced 2007 JKUR); 2016 Durango Brass Monkey edition; 2011 Expedition; 2002 Trans Am WS6 6spd
@R 3 Do you guys have any pictures of your door sills installed? Are they black like the pictures on your website?
https://www.r3offroad.com/product-page/jeep-jlu-door-sill-gaurd
No, they are the same clear 3m film. I just put hinge and sill protectors on my 4 dr. The hinges are actually easier to get on ... and the die cut makes it worth the $ after you realize what a pain it would be otherwise. The sills are harder to get on good just bc of the angles, curves on the Jeep and size of the film piece but if you do hinges, then rear doors then front you will have the best chance of getting a good result by building your ‘experience’.
Kerfien
Lesli
South Dakota
2018 JLU Sport S in Mojito! 1998 Eclipse Sypder. 1993 Honda Prelude
Just placed my order! My JLU is being delivered tomorrow! Thanks!
aug0211
Ohio
JLUR 4xe
Man, I should not be installing my own. I’m way too much of a perfectionist and my skill with this is not even close to my expectations. It’s by no means “bad” - but I really want perfection and I just can’t get it.
2 hours so far, and only the rear doors are done. Busted out the heat gun to help, and using a mixture of water + Johnson & Johnson baby shampoo + alcohol in a fine misting spray bottle. Torture.
Again, it’s not because the product is poor - it’s becsuse my skills just aren’t where I want them to be.
R 3
R 3
louisburg, KS
www.r3offroad.com
2018 jlu rubicon 2008 jku 2006 lj
@R 3 Does the door sill film come with an applicator tool
@Simon311
No it does not come with a applicator tool, a cheaper alternative than the silicon type of applicator tool is a body putty spreader i.e. Bondo brand you can pick up a pack of 3 different sizes at auto parts stores pretty cheap I think 5-10 dollars.
OldGuyNewJeep
Don
CT
@Simon311
Supermarket rewards card worked fine for me.
Warpath
St. Louis
drock317
Derek
Indianapolis, IN
My Top Golf member card worked on mine. However it took a lot of work to get my cut outs off the paper. The @R 3 cutter didn't go deep enough through the vinyl. Had to use an exacto knife to cut along all the edges and and peel off the excess so I could get them out. Added some time, but still worked out well.
Status
