Door harness pins
Bomeo
Beau
Henry, IL
2018 Wrangler Sahara JL
Jeep needs to recall 2018 Wrangler JLU door harnesses. There is an issue everyrime I take my doors off. They need to at least give us a schematic on what pin controls what function so we know where our problem is.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Happened to me as well. Take the harness apart and look at the pins... Most likely bent a few. You can carefully straighten them out, preferably with a toothpick or other non-metal tool. Don't want to short anything. The plugs have to be perfectly square when you put them back together. Shouldn't be that precise but it is.
Bomeo
Beau
Henry, IL
I straightened all of the pins and my mirrors don't work and two doors don't lock. Anyone know what pins in each door control within the Jeep?
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
I unplug mine in the spring and plug them back in in the fall when temps hit 30 ish.
Less chances for problems.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Possible you blew the fuse.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
How many wires go into the door? (can't remember) could always clip them all and repin them and run smaller more reliable weather packs or deutsch connectors. Hell, could even go wild and use mil spec twist lock connectors.
