Differences between LT tires with imperial versus metric sizing?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
BFG KO3s won't be coming out in 37s (37x12.5R17LT) until sometime in 2025, but that's with an extremely stiff sidewall rating of F. The D rated variant won't be available until sometime in 2026!
LT315/70R17/Ds, however, should be available sometime next year. In theory it's about the same size as my 37" KO2s. I'm thinking that they're basically the same tire, but is that a valid assumption?
See https://dgaddcosprod.blob.core.wind...ents/clz74riy502c701kqq5h7lyvi-v5-bfg-ko3.pdf
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
The height x width tires were/are called flotation sizes. They existed before metric sizing came to be. The manufactures still market that way because it’s easier for the general public to understand what they are getting, even though often times the same tire company will market a close metric equivalent.
The best thing you can do is choose the size of tire you need with the desired/proper weight rating. Sometimes it’s in a flotation size and other times it’s in a metric size.
Just some of the things I learned working in a tire shop in my younger days.
The Last Cowboy
San Antonio, TX
I don’t think there is a metric equivalent for 37s until you get to 20ā€ wheels. Then you’re looking at load range G at least.
Edit. I found the metric size for 17ā€ wheels. 315/80R 17. Nitto makes a tire in that size, or they used to. Can’t find it now.
azwjowner
Phoenix
Edit. I found the metric size for 17ā€ wheels. 315/80R 17. Nitto makes a tire in that size.
BFG used to make the KM2 in 345/75R16. Now that was an oddball size, but 37 inches.
2nd 392
Ca
Crap, I was thinking LT315/70R17 were basically 37s. They're just a bit over 34s. Shit.
Check tiresize. com for a metric 37/12.50 equivalent. I don’t recall seeing one. I know AT3’s in 35/12.50 are C or E, the same spec tire except D rated is listed 315/70. 37’s are either 12.50’s or 13.50’s, no metric equivalent.
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
315mm = 12.4" * .7 = 8.68 * 2 = 17.36" + 17 = 34.36"
315mm = 12.4" * .7 = 8.68 * 2 = 17.36" + 18 = 35.36"
35 x 12.5 x 17 = ~35 x 12.5 x 17 :)
Ratbert
Ratbert
PNW
Software Engineer
Yeah, it looks like I'll either have to go with 37" KO3 Fs or find something else. I'm thinking the F is going to be pretty bad on and off road. I can't imagine that they'll do well when aired down to ~12 PSI.
azwjowner
Phoenix
Find a used set of KO2s to last you one extra year. Or the Toyo Open Country A/T III is a pretty close match to KO2s/KO3s, and it comes in 37x12.5R17 in load E.
Ratbert
Ratbert
PNW
Software Engineer
That's an interesting idea to get used KO2s to make it another couple years. Or just screw it and buy something else.
The Last Cowboy
San Antonio, TX
2nd 392
Ca
Toyo 37/12.50/E is 73 lbs. just under 5 lbs heavier than KO2 D’s. Lighter than Cooper D’s, Falkens weight need not be mentioned….. 😁
Gangplank
Vero Beach, FL
2021 JLU Willys 3.6 eTorque w/ Mopar lift. 2022 JLU Rubicon 2.0T still stock
Nitto has a few 37s in D
Trail Grappler - MUD
  • 37x12.50R17LT D 124Q
  • 38x13.50R17LT D 121Q
Ridge Grappler - Hybrid AT
  • 38x12.50R17LT C 118Q
Recon Grappler - AT
  • 37x12.50R17LT D 124R
  • 37x13.50R17LT D 125R
