Did some t case & diff fluid change at 15k miles
supermike
mike
Irvine CA
18 JLUR 6 speed 2021 JLUR 392
So happily rolling over 15000 miles and no mechanical problems and dealer visit yet, most reliable Jeep I owned so far, while doing the oil change, I also Change the transfer case fluid just out of curiosity because when I change my Raptor's t-case fluid around 10k miles it was pitch black. Since they are similar clutch t case I'm glad it was clean clear red fluid and should not be worried for a long time. Diff was another story, it was DIRTY, you really should change the 1st fluid early and flush out the break in garbage.
transfer case took a little over 2 qt, front & rear diff fluid was little less than 3qt total.
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG313
Front diff was looking ok.
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG314
Rear diff was dirty, and had odd smells.
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG315
It was extremely dirty inside the rear diff as well, ring gear and locker sensor was all coated with black fine metallic..
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG316
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG317
very happy to see the clutch t-case looking clean.
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles WechatIMG318
Ormond Beach, Florida
Retired at 55 ..
MSparks909
Miles
NC
JLU Rubicon 3.0
I’m a firm believer in 15K fluid changes on our axles. Also recommend running a 75W-140 synthetic front/rear. I changed mine at 1100 miles when I potted my locker sensors and it was pretty grey…glad I got the break in fluid out!
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
After years of manually pumping oil into my differentials, transfer case and transmission, I finally broke down and got one of these
Jeep Wrangler JL Did some t case & diff fluid change at 15k miles 61j0yaXeywL._AC_SL1500_
It was worth the money. Makes the job easier, especially with limited room under the vehicle.
If you get one, get it with the brass shut off valve. The plastice hose clamp leaks fluid and makes a mess. :)
Rob97RR
Rob
Northern 'burbs' Chicago, IL
22 392 XR Rubi, 2023 C8 Corvette Z06 & 2023 Ducati
Stay at home dad to 2 munchkins, best job in the world!
...Front diff was looking ok.
Mike, is it possible that the black stuff you saw in the rear diff was from the AEV diff cover you've got, like it had a faulty coating or something? Or did you just now install that when you changed the fluids?
supermike
supermike
mike
Irvine CA
this was the factory cover and AEV cover was installed after the fluid change....I guess with a v8 more torque was applied and more wear?
