Defiant DF01 wheels
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Good looking rim! Maybe more of an XR knockoff than a Borah, but reasonably priced for sure.
WhoaBlackBetty
WhoaBlackBetty
Seth
North Carolina
2021 Jeep Wrangler Unlimited Willys
They do also look similar to the XR wheels that come with less bolts aside from the color.
Jeep Wrangler JL Defiant DF01 wheels IMG_7140
Jeep Wrangler JL Defiant DF01 wheels IMG_7141
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
They are an XR replica with the same offset.. I was tempted to get these, then the 8" wheel width dissuaded me from it.
WhoaBlackBetty
WhoaBlackBetty
Seth
North Carolina
Yeah they are 8.5 worth but I wish they were different offset. I plan to run 37s and ditch these 35s
Jeep Wrangler JL Defiant DF01 wheels IMG_5323
amadeus303
NJ
2021 HBP JT Overland 6MT, 2023 BW JT Mojave
The specs on Amazon under the OE store suggest they're on the heavy side...41 lbs each!
Single Wheel
But inside their Amazon store, they also sell a set of 4...and based on the specs there, it suggests each wheel weighs 35 lbs ?‍♂
Set of 4
I'm interested in these as well as their website notes that some of their wheels will accept Mopar center caps, and I prefer an OEM look.
GrayWolf.Overland
Subash
www.instagram.com
Defiant DF01 Satin Black ❤
In case any one is on the fence about this.. these look fantastic and pretty much similar to the OG XR wheels from pre-2022 JLUs
jeepstylin
Michigan
1985 Jeep CJ7 Renegade, 2020 JLU Rubicon
I did some research on these wheels, as I was thinking the same as you. They are about 20 pounds heavier than the OEM XR wheels. Also, the trim ring is glued on. I like having the ability to swap out rings if they get beat up on the rocks. If these issues were not a concern for me, I probably would’ve bought a set. I ended up just buying some XR takeoffs for my JLUR.
njjeepher
Christie
new jersey
2025 jeep wrangler sport s
thinking about buying these wheels…what size tires are you running here with them? Looks great!
GrayWolf.Overland
Subash
www.instagram.com
These are 37x12.5r17 BFG KO2s
