Dashboard Buzz when brakes or blinkers used
Mmcnulty
Michael
Charlotte, NC
2018 Wrangler JLU Sport
My 2018 JLU sport recently started getting an electric buzzing noise when I press the brakes or use the blinkers. The buzz is constant when the brakes are depressed, but buzz on and off with the blinkers. I did have the radio and speakers changed professionally over the summer. I took it back to the stereo place but they couldn’t find any faults. It’s very low volume and doesn’t come through the speakers.
Beachcomber72
2022 JLU High Tide
our radios/head units are a on canbus system. Multiple devices/issues can arise from switching it out if the interface harnesses aren’t correct. But beyond that I’d trace down the rear turn signal/brake light circuit since both are sharing a common ground if I remember correctly.
Mmcnulty
Michael
Charlotte, NC
thanks. I did buy a premade harness that had all the plugs attached, so nothing had to be spliced. Any idea where I can find a wiring diagram for the circuit?
Beachcomber72
2022 JLU High Tide
I’m currently getting my diagrams from ALLDATA. But I have a subscription to the service.
Mmcnulty
Michael
Charlotte, NC
jludave
The Isle of Long
IT Manager
Any idea which relay it is or where it’s located?
All relays should be in the Power Distribution Center (PDC/Fuse/Relay box) under the hood. There is a label/diagram on the under side of the cover that should tell/show you what's what. Exterior lights should be relays F26 and F29.
