Dash & Shifter Light killing Battery
Go4Low
Go4Low
Jorel
2020 JLUR
Any update on this.. i am having a similar issue.
I have the genesis kit. Drove my jeep for about an hour sunday, then tried to start it on tuesday and both batteries were stone dead.
The problem I posted on this thread has nothing to do with the Genesis dual battery system.
The cause of the problem and the solution is on post #12.
I hope you find a solution.
Suffolklou
Lou
Richland Wa
2020 JLUR
At the very least, you aux battery should not die. The genesis kit separates them at 12.5 ish volts. You should double check that it is installed correctly and contact genesis if it is. They are very responsive.
