Cover/Replace/Remove Amber Yellow Reflector Side Marker
DToxic
Blake
Bay Area, CA
2018 JL Rubicon
Finally someone made them! Ordering some now to give them a shot
can you post pics and thoughts once you get it? Very interested but seeing if it's worth the $70!
paulr
paulr
2018 Sting Gray JLUR
Here are some pics, I went with clear because the smoked wasn't "smoked" enough for me, it was kind of like in between so depending on the light/angle you would wonder if they are clear or smoked, so just stuck with clear. The quality is very nice, install is easy, just remove 3 plastic rivets with a trim tool and a couple bolts and it comes right out (no need to remove the entire fender or liner)
EDIT: here's a great thread with install instructions (not by me) https://www.jlwranglerforums.com/forum/threads/retrofit-side-marker-install-with-pics.20803/
Clear (before they were fully installed or tightened down, hence some gaps, I was still deciding on color):
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1314
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1315
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1316
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1317
Smoked (before they were fully installed or tightened down, hence some gaps, I was still deciding on color):
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1318
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1319
Final install clear (pardon the snow, only pic I have for now):
Jeep Wrangler JL Cover/Replace/Remove Amber Yellow Reflector Side Marker IMG_1408
Diode Dynamics
Summit Sponsor (Level 3)
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
Post bump!
We just released our new LED Sidemarkers today! They're computer-designed for perfect alignment with the DRL right out of the box, and feature a full strip of high power LEDs. Unlike other options, these require zero adjustment or modification, and feature OEM grade retroreflector optics and housings. They're available in your choice of clear, smoked, or amber. The clear option creates a unique "wraparound" effect with the DRL that looks super clean!
Installation is can easily be done at home in your garage using basic hand tools. I'm certainly no wrench, and I installed a set on our shop JL in under 45 minutes (I'm DEFINITELY on the slower end, haha!).
We manufacture our LED Sidemarkers at our facility right here in St. Louis, and they're backed by our 3-year worry-free warranty!
Feel free to shoot us a PM with any questions! Also, I'm happy to offer free USPS shipping on these for U.S orders, just let me know if you need the code!
Jake H.
Diode Dynamics
