Cost to Replace Jeep JL Backup Camera?
Mathami
Saeed
Riyadh
Wrangler JL 4D Sport
I have a JL 2020 Sport without rear camera(which I totally regret) , I bought the camera (68452959AB) and couldnt find any harness or cables related to it on MoparOneonline to connect it from the camera to the car screen , are they by other name or part number? because the part mentioned( mopar high mounted stop lamp wiring ) looks short, thanks.
Atom631
Atom
New York
2021 JLUR
Does anyone know the part# for a 2021 backup camera?
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
My rear view camera lens got scratched somehow and I just ordered the replacement. Was this a complicated install or pretty straightforward?
It’s been awhile but Do you have the part # for just the lens? Been searching and haven’t found it yet. I just need to place the lens as mine for broken. Thanks!
Rb75
Robert
Portland, Oregon
2018 Wrangler Unlimited Rubicon
Sorry, I'm just seeing this. Did you find the part? I have the receipt - Part Number 68452959AB "Camera-Rear View" and paid $92.74 at MoparWholesaleParts.com. I found a video on Youtube that made the install pretty straightforward.
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
Are there any other options for higher quality backup cameras that wire up and work like stock?
Higher quality? I got to be honest, this is one of the best 'looking' cameras I've seen! Super high resolution and colors look great. My only complaint is that low light could be better. Not sure if all cameras look the same on different infotainment screens, but mine is the 7".
Kind of hard to take a picture of it, but even here looks pretty good.
Jeep Wrangler JL Cost to Replace Jeep JL Backup Camera? 20210528_152010
discobean
Sydney, Australia
JLU
Yes, in 2021 models I hear the rear camera quality dropped significantly, and I can tell a huge difference between my front camera to the rear camera. Both in day and night.
beachbumm78
Kristy
Phoenix, AZ
Thanks. No I don’t have the part yet so that’s great timing. Thanks for the part #. I’ll go purchase. Good to know about the YouTube video as that’s the next step. Lol.
elieah
Elie
Qatar
2018 Wrangler JLU
Hello! i tried searching youtube for that vid but couldn't find it... can you please share the link?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@elieah
Not that difficult... here is one video that shows the deed ... The guy in the video actually did a very decent video in regard to this....
Rhinebeck01
Retired at 55 ..
Careful, when you remove that black plastic panel on the inner of the tail gate....
It is really easy to have one of the green retaining clips fall into the hole that holds the clip on the tail gate itself.
Part number for the green clip is Mopar 0651 1829 AA (they cost about $.66 each)
The green clips can be had in packs of 5 and part # for the 5 pack, is Mopar 0651 1829 AA-005
Rhinebeck01
Retired at 55 ..
Forgot to mention....
When you go to release the red connector in regard to the 3rd Brake light.... you need to release #1 in the pic below and then push in firmly on #2 and hold in, in order to get the connector to release.
Gutys/gals will often release #1 and then fail at their disconnect attempt because they are not aware they have to press in and hold #2 in the pic below..
I use a nylon spudger tool to depress #2, but you can use a small flat tip screwdriver, etc..
So, release #1 and then push in #2..... hold it end and then gently wiggle/pull connector loose.
DO, do remember #2 .....! Why, because you will find over your lifertime, that #2 and need to deal with it ...... to disconnect a connector on a few different connectors on the JL.JT... other vehicles...
Jeep Wrangler JL Cost to Replace Jeep JL Backup Camera? 2222
elieah
Elie
Qatar
2018 Wrangler JLU
Thanks a lot for the detailed explanation, much appreciated.
Newtopia
Zach
Allentown
2018 JLU Sport S Wrangler
Hey guys just want to give a heads up there are two different rear cameras used in the JL wrangler. Found out the hard way. #68288397AC (older version) and #04672585AB. My 2018 had the camera ending an AC and I replaced it with the camera ending in AB because they looked identical and AB was cheaper. Only to find out you’ll get only half a screen and a static like line in the bottom of your screen, guide lines also won’t work. All issues resolved when replacing with the AC model. So just be aware which one you have before replacing.
Jeep Wrangler JL Cost to Replace Jeep JL Backup Camera? 26B885C2-FF58-4F6C-98D9-2AA9F608BCD7
Jeep Wrangler JL Cost to Replace Jeep JL Backup Camera? 37FBF68F-0559-4C70-81EF-615AF6102BCC
