Corral Canyon - 5/25
Craigger
Craigger
San Diego, CA
2022 JLUR XR
Crawled underneath before my scheduled inspection tomorrow and I am pretty sure I found the culprit to my highway vibrations. A torn drag link/pitman arm boot.
Man, I hope that's it. Or something simple at least. Pitman arm is pretty high - do you think you snagged it or does it seem prematurely worn?
Inkhero
Travis
San Diego
2022 JLU Rubicon 4xE
None of the components appear damaged or worn, and I've inspected all of the bolts to see if the paint lines match up. So far, only things of note were:
Pitman Arm boot is ripped
Tie Rod Jam Nut was hand-loose
Bashed Rear LCA skid plate
So it could just be everything needs to be re-torqued, replace the boot or maybe the whole ball joint at the Pitman arm, check the tires for balance issues, and maybe an alignment. If those don't fix it, I got my measurements for a replacement rear driveshaft on the back burner.
Craigger
Craigger
San Diego, CA
2022 JLUR XR
I'm thinking the loose tie rod will do it. Yes, make sure everything is torqued down - while you're at it check the track bar. Hopefully you're good to go for Corral Canyon.
Inkhero
Travis
San Diego
Jeep is back from the shop with no more vibration.
Tires rebalanced, i lost a hilarious amount of wheel weights on 3 of the wheels.
alignment done, minor toe adjustment
everything re-torqued
I ordered a replacement drag link end boot, gonna install that and should be ready for the trails next weekend 🤘
Craigger
Craigger
San Diego, CA
2022 JLUR XR
Awesome!
Go1712
San Diego
2020 JLU Sport S
You think I’m over reaching on 35’s? If not I’m down to go
Craigger
Craigger
San Diego, CA
2022 JLUR XR
I’m on a sport so only rear LSD
You'll be scraping quite a bit and will have to winch over many obstacles. I did it in my TJ a couple of decades ago (Rubicon so f/r lockers) and my memory of it is very dim but all the current reviews are saying that lockers are hugely helpful.
Craigger
Craigger
San Diego, CA
2022 JLUR XR
OK folks - I'm thinking meet at the trailhead at 8am. Anyone who wants to go who hasn't chimed in yet?
GMONEY
Greg
Temecula California
23 2D Rubi Earl
I'm going to be out this weekend. Need to get a replacement spare tire still and haven't really been home for 2 weeks.
Pig-Pen
Banned Camp
2018 JLU
jabroni
id be interested but it seems like it may be a little too tough for me. i only have the junky oem lsd in the rear, with a locker up front. watching some videos on YT, it looks like there are some tough spots!
