Constant tone from radio
47Jeepster
47Jeepster
Tom
Queen Creek, Arizona
2025 JLUR X ... 2023 JLUR Diesel ... 2018 GC Summit
This issue just started with my 2019 Sahara. Constant tone coming from the radio. It would cut out if I used the phone and then start back up again. Turned the vehicle off then started back up and the constant tone was still there. Very annoying!
Try pulling the #11 fuse for awhile to reboot the radio. If that doesn't work your dealer and @JeepCares are your friend.
Ryder
Dian
PNW
Unlimited Sahara 2019
Jeep dealership printed a copy of a Case Number S1908000048 - Rev. A opened on 9/17/20.
"Repair Procedure: Do Not Replace the radio. A radio reset by pulling radio fuse or battery disconnect corrects the concern. A future radio software enhancement will correct this concern. Tenetative availability: 1st quarter 2021: Verify radio software MR 28.3 or higher:
bhold
Boston
Grand Cherokee 2019
"A future radio software enhancement will correct this concern. Tenatative availability: 1st quarter 2021: Verify radio software MR 28.3 or higher:"
Is anyone from JEEP still monitoring this thread? There are seven pages of discussion about this issue going back years. Many owners have been documenting this carefully and posting in good faith trying to be helpful to JEEP and other owners, yet still there is no fix. I'd really like to believe that JEEP will release a patch in 1Q21, but based on their track record I'm not hopeful. Competition is about to heat up - if they continue to take us for granted it may be time to look at alternatives...
Chad
Haymarket, VA
18' Sahara JL, 14' MB E550,13' S6 , 07' Ram 2500
AMT
Well I now have this issue also and am worried about it getting fixed. My warranty runs out on 3/31/21. Has anyone had any luck getting this fixed?
Thanks
Chad
Mucktheghost
Ram
I have this exact same problem with my RAM 1500 UConnnect 8.4. I am able to reproduce the problem. It seems to occur when the satellite signal is weak and/or has inference. This problem occurs when parked in a parking structure with spotty satellite signal. My theory is that if the vehicle is being started after being parked for about an hour or more, UConnect tries to downlead your system subscription information or some other download from the satellite. Because the signal is weak or has interference, the download is interrupted and that causes the system to error out with the "constant tone". Parking the vehicle for about an hour with the ignition off usually resolves the problem, if your not in the same satellite interference condition. You can also pull the fuse or disconnect the battery and resolve it immediately, but then all your setting are lost. Not convenient. So far, UConnect, Chrysler, Dodge, Jeep, Mopar, Fiat, etc. don't seem to want to acknowledge the issue. Always referring me back to the dealer, who resets the system, and all my settings, and sends me on my way. They suggested that a new computer/radio unit might be needed but I suspect a software update is all that is needed. Hopefully soon they will address the problem.
47Jeepster
47Jeepster
Tom
I have this exact same problem with my RAM 1500 UConnnect 8.4. ... They suggested that a new computer/radio unit might be needed but I suspect a software update is all that is needed. Hopefully soon they will address the problem.
I understand that there is an update being downloaded to the radios in this time frame. My wife's Summit (that never had the problem) received the update last week. So, if it doesn't show up soon, you might see about forcing it. And, do get back with what happens after the update.
47Jeepster
47Jeepster
Tom
@Mucktheghost ... yep, there is an update for the 8.4 radio. Just hit mine today, but I was on a trail so delayed it until this evening.
PatrickM
Patrick
UK
Jeep Wrangler JLUR
what version was your update?
Because here we are , December 2021 and my 2019 does this intermittently. There's no fix AFAIK, and usually the radio resets itself after a day or so....no discernible pattern...maybe 3 starts after a few hours.
This morning it started again. An hour later I'd parked up but had trouble starting the jeep. The. driver display showed that I had to place the key fob by the start button. Thankfully it started....but the persistent noise was still there.
Mine settings shows
UConnect LIVE 3.1.0
Update Manager 2.1.0
When I went to the jeep just now, I had to touch the key fob to the starter button just to switch from OFF to ACC. Then it seemed fine and the persistent tone had gone.
This is very strange.
47Jeepster
47Jeepster
Tom
Mine settings shows
UConnect LIVE 3.1.0
Looks like you might have two problems. With instructions to place the key fob next to the start button, that suggests that you have a weak battery in the key fob. Batteries are cheap, try changing it out.
As to the update ... let me look up the magic key strokes to bring up the version that I currently have in the radio. Will do that later today. I did install the update back in February of this year, so it should be the latest ... well, at least as of 9 months ago.
47Jeepster
47Jeepster
Tom
@PatrickM
I hope there is a special place in hell for IT folks who constantly change the location of info. *&^#$%.
Remembered where the software info was stored, checked and it's not there anymore. A quick search of Google yielded a Youtube video that showed the new location ... thanks Mr. Haneline.
My radio software version is 21.11.11
PatrickM
Patrick
UK
Jeep Wrangler JLUR
@PatrickM
I found a UConnect website where I put in the VIN and it tells m I’m up to date
Jeep Wrangler JL Constant tone from radio C9CA6450-CBF3-4AFE-8188-1910097028BE
