Compatibility Issues Between Flush Mount Taillights and Bumper Reverse Lights?
JP29
Zach
Olathe
2020 JL Sport
Hi guys, I'm having intermittent issues with these two items. My Jeep is a sport model that originally came with halogens, so not sure if there's any issue between them. The flush tails have been flawless, I did initially install them with the resistors. When I installed the bumper reverse lights, I noticed sometimes the bumper reverse LEDs and also the drivers side reverse in the tail light stop working. Is this a common or known issue?
Smoke Showing
South Jersey
2018 JLU
Check your connections. I tied the 2 bumper lights together then just stripped the driver side reverse light wire, folded it into a crimp, then added the bumper lights. I didn’t cut the wire. Never an issue with halogen lights and lED bumper lights. I also add de-ox to all crimps to help with corrosion. It’s an electrical lube/ corrosion inhibitor we use on service cables in meter sockets.
JP29
JP29
Zach
Olathe
2020 JL Sport
I've given them a solid twice over, all connections use factory style plugs except for the bumper back up lights - those have spade connectors that tie into an adapter on the left driver's tail. Worst case I could remove the bumper to get at them and check the lights themselves, but a bit of a pain so figured I'd ask around.
Smoke Showing
South Jersey
2018 JLU
Possible the resister isn’t sized to handle all 3 lights. you have 2 extra lights on one of the resisters. Can you split the bumper lights to each side reverse light to lessen the load?
JP29
JP29
Zach
Olathe
2020 JL Sport
If I remember right the bumper lights are interconnected, right side to left and then left side to driver tail. Didn't appear to be an easy way to split, but I might need to look. I tried disconnecting first one and then both of the tail light resistors, but didn't appear to have a positive affect.
JP29
JP29
Zach
Olathe
2020 JL Sport
Well, this is what Jscan is telling me - care to comment @ORACLElights ?
Jeep Wrangler JL Compatibility Issues Between Flush Mount Taillights and Bumper Reverse Lights? Screenshot_2023-05-13-09-47-16-79_ef018c1758006d5620910fdaa2ccdc6a
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Double check that each T-tap is fully seated and making sold connection. If all connections are solid, then take a moment to fill out our online warranty request here: https://www.oraclelights.com/RMA and someone from our customer service department will be in contact with you shortly. Thank you! DM us with your email address so I can follow up with our customer support team.
If the team gets back with any other steps, I'll post here.
- Terry
