Pilotjeep
Hi, folks. I've looked through the threads I was able to search up, and haven't found a clear answer. This question is about a charging-related error message, and on battery specs and replacement.
Vehicle: 2020 JLU Sahara, 2.0 turbo with eTorque (confirmed from build sheet and from window sticker), w/ tow package, built in mid/late 2019
Symptoms:
Diagnostic info:
Questions:
Symptoms:
- receive "aux switches disabled, battery charging" status message in dash either when starting, or when engine start/stop stops. This happens most of the time, and possibly doesn't happen after long trips.
- sometimes remote start from keyfob doesn't work (at the same distance and position that it usually works).
Diagnostic info:
- gauge reads 11.6 V before a cold start, following overnight rest
- gauge quickly ramps up to 14.5 V with engine running. Eventually gets to at least 14.7 V.
- gauge drops to 11.8 V while parked with engine off after a short drive
Questions:
- I believe the eTorque engine has a 48 V battery somewhere under the back seat? Or does it have the small battery below the fuse box (which I have seen indicated for the 2.0 ESS engine, not the eTorque)? Or no secondary battery?
- Owner's manual says "may be equipped with" the small battery under the fuse box, and says nothing more, but I don’t trust that I have the right version of the manual.
- When I called the local dealer, they first told me I have no secondary battery, and then quoted me $2600 for a secondary battery, which I hope is complete mistake and is actually for a 4xe hybrid battery.
- I assume the error message is due to needing to replace the battery or batteries. The question is, which one, or both (if there are two)?
