Balor
Billy
Kissimmee, FL
VW
We have been stewing on these for a while. Body mounted sliders just don't get the job done, and most of the frame mounted options out there don't look great or cant function as a step! Our HardLine Rocker Guards are manufactured form 3/16 steel plate and incorporate a unique approach to rocker guard design that allows you to remove the fully welded outer shell for cleaning, painting, or replacement if you somehow manage to damage the outer shell.
These things are absolute BEEF
20% off Introductory Pricing will end in the next few days, when it does end, our JL forum discount code will work (they are not stackable).
Jeep Wrangler JL CavFab - HardLine Rocker Guards {filename}
FEATURES
  • Available As a Bolt on Kit / Weld on Kit / or Long Arm Suspension Compatible
  • 3" step
  • Made from 3/16" American Steel
  • CNC Laser Cut and Formed
  • Made in U.S.A.
  • Ships Raw Steel
  • Long Arm version requires welding on all frame mounts
WHAT'S INCLUDED
  • 6 Rock Slider Frame Mounts
  • Driver and Passenger Rock Sliders / Rocker Guards
  • Mounting Hardware for bolt on
  • 3/16 Aluminum or Steel Outer Skin optional
Find Them HERE: https://cavfab.com/products/jl-rocker-guards-4-door
I didn't see them available for the Gladiator, are you going to make them available for the gladiator?
Xploring_Outdoors
Sean
2025 Jeep Wrangler Unlimited Rubicon
What are the differences between the weld-on version and long arm compatible version In terms of the mounts?
Any photos?
Also, any edge views showing amount of “step” from the body?
Thanks
I would like to know how the weld on mounts/long arm mounts work as well. Do they mount in a fixed location on the slider body, or can the mounts be welded anywhere along the frame to accommodate for different long arm setups?
CavFab_mfg
CavFab_mfg
Summit Sponsor (Level 3)
CavFab
Wildwood ga
2018 jlur
Aftermarket Jeep Product Manufacturer
some photos from a few trips to hard trail would be convincing.
We have ran this design (slightly different aesthetic) for 2+ years wheeling from North Georgia into Moab, and up into the Oregon Coast). This design has been put through a ton of testing.
CavFab_mfg
CavFab_mfg
CavFab
Wildwood ga
2018 jlur
Yes - 11/7 Release for the JT and JL
CavFab_mfg
CavFab_mfg
CavFab
Wildwood ga
2018 jlur
@CavFab_mfg
Also any pictures to show step area from side to see stick out? Maybe measure it?
I just ordered 1 set of LOD signature sliders (had 2 in cart) i can im order details to yall to see im not kidding, a few minutes ago and need to order a set of sliders for mine, Or hers depending on which ones she likes better.
We have mangled 2 sets of stock rubi slider things 🙄 in just a couple of outings, so frame mount w/o welding is ideal. (Even these can still be welded on if need be)
Like this?
They stick out 3.75" at the B Pillar.
Jeep Wrangler JL CavFab - HardLine Rocker Guards 6580810455743805043
CavFab_mfg
CavFab_mfg
CavFab
Wildwood ga
2018 jlur
Quick question since I was ready to hit send on a set of lod ones...tonight
Since they are 3/16 steel, why do you need another layer of 3/16 steel or alum.?
@CavFab_mfg
The skins allow you to replace or have a piece to remove and 'clean up' on the outside edge of the slider body. This way, the skin is what is getting mangled and not the body of the slider. They also clean up the look in my opinion. They are optional, and can be added down the road if you dont want to get them to start with.
CavFab_mfg
CavFab_mfg
CavFab
Wildwood ga
2018 jlur
Yes,I quoted myself
It's 50/50 for adding another layer of protection and adding style to something that is traditionally designed around pre-engineered structural shapes.
no skin at all is very strong and provides a really clean look. but if you want to drive by brail 3/8" worth of steel plate is fun to think about turning boulders into gravel with pure 🥩
We are going to run the ones on our JL as the bolt on option with aluminum skins to show how strong this kit is until our JL longarm kit is available. and then we will switch out the mounts to the weld on longarm compatible rock slider version.
Our JT will have the weld kit on from the start to accommodate our JT longarm kit.
CavFab_mfg
CavFab_mfg
CavFab
Wildwood ga
2018 jlur
The sliders themselves are 94lbs / for both left and right side.
the brackets are another 45lbs for all 6 frame brackets.
this is without any skins.
azjl#3
North AZ
can you install skin when it is bolted to frame?
azjl#3
North AZ
looks like pic of brackets are bolted, nut not all bolts used?
azjl#3
North AZ
any future chance to do this and keep oem rubicon slider in place, sure looks like it would be easy.
