Can someone verify this combination?
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
Looking at BBAT:
Baja Boss A T
Material #: 247490
Legacy Material #: 90000036824
Legacy Part #: 53772
Product #: 331040001
Also going to install Clayton Offroad 2.5 overland plus and they require 4.75 backspacing, said nothing about offset.
I am looking at this wheel with zero offset - 701 | Matte Black – MR70178550500 – Method Race Wheels
  • Part NumberMR70178550500
  • Wheel Diameter (in)17
  • Wheel Width (in)8.5
  • Bolt Pattern5x127 (5x5)
  • Offset (mm)0
  • Hub Bore (mm)71.5
  • Back Spacing (in)4.75
  • Wheel Weight (lbs)31.69
  • Max Load (lbs)2650
Anyone running this combo?
2nd 392
Ca
8 1/2” wheel 0 offset is 4.75” backspace. The question is ?
BTW- 12.50’s tread is ~ even with XR extensions
WannFly
WannFly
Priyo
Atlanta
Cyber security
:facepalm: clearly I do not understand offset and backspace. Sigh.
Just trying to get a 2nd set of eyes on the combination and ensure I dont have send anything back because of my lack of knowledge.
PT's19Rubi
Paul
NC - Just across river from Uwharrie trails
2019 Rubicon 2D, 3.6, 8A
Retired Electrical Design Engineer
Wouldn't that be 4.25" backspacing (half of 8.5 width)? Or, are you adding 1/2" for bead seat?
2nd 392
Ca
Using the posted tiresize.com site chart. According to it -12mm is 4.25” . Basically yes, if I understand you correctly.
Wheel backspacing is the distance in inches from the wheel mounting surface to the inside edge of the wheel. The wheels width is from the mounting points of the tire beads, therefore the measured width of a wheel from outside edge to outside edge is about an inch wider than spec.
PT's19Rubi
Paul
Aah, I see. If wheel width is measured from bead seal to bead seal, and the distance from bead to edge of wheel is being called 1/2", then 4.75" for backspacing is correct. Given most people would measure from the edge of the wheel, 4.75" is better than the actual 4.25".
2nd 392
Ca
I recently made the same mistake ordering water timers. Water pipes are inside measurements. Ordered 1”, needed 3/4”, and had to get reducers, oops.
