Can’t Clock Window Handles?
highway star
Hernando, MS
2024 Jeep Wrangler Sport
Took the Jeep to the dealer for 1st oil change & asked em to clock window handles where I put the tape. They said it can’t be done.. Are they for real?
Jeep Wrangler JL Can’t Clock Window Handles? IMG_9336
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
No. I've had 8 doors with cranks replaced and the positioning of the cranks has been random on the replaced doors. It's fairly easy to do yourself with a window crank removal tool.
Reinen
2021 Jeep Wrangler JL Rubicon
They're correct, it can't be done.
Clocking to a specific position requires far more intelligence and common sense than their current techs have. You'd be lucky if they even know what a window crank handle is.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Depends on the shape of the shaft. I’ve seen some that are square, and obviously there’s only 4 possible positions. However, most are splined and have probably 15 or 20 possible positions.
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
J.Ferreira
www.tmgps.org
1999 Jeep XJ
Splined on the Jeep, and they use like a slip ring thing that hold them in place.
Remove, place where you want, and smack back on.
Deleted User 38384
I used a towel when I adjusted mine. I positioned mine so they point up.
I think it's straight up with window fully rolled up and slightly forward with window rolled down.
Used to bang the fuck outta my knee off road otherwise.
Same thing here, being 6'5", my driver side window handle is set in the one position where my knee doesn't bump into it. Every other window handle position is set to match the front driver's door.
