Cambio de halógena a led
Juanbello79
Juan
Tenerife
Wrangler SPORT JL 2.0 272cv
Después de cambiar en mi wrangler JLU sport del 2018 las luces halógenas por las originales LED DE FÁBRICA, me doy cuenta que al poner las luces largas o altas, las cortas o bajas se apagan, será problema de solucionar con JScan?
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
After changing the halogen lights for the original FACTORY LED lights in my 2018 wrangler JLU sport, I realize that when I put the high or high beams, the short or low beams turn off, will it be a problem to solve with JScan?
I don't see that as an option for either JScan or Tazer, but figured I'd auto-translate your question in case anyone else knew for sure if you could configure both high + low to run at the same time. Might be a limitation of the OEM LED headlight design.
Juanbello79
Juan
Tenerife
After changing in my wrangler JLU sport of 2018 the halogen lights for the original FACTORY LEDs, I realize that when I put the high or high lights, the short ones turn off, will it be a problem to solve with JScan?
