Halogen to LED DRL - Do I need a dealer code?
ZgsProduct
Pure Michigan
2018 JLUR 1987 YJ
Good Morning,
I have a 2018 Rubicon that came with non-LED lighting from the factory. Over the time of ownership I have upgraded my taillights, headlights, & just recently my DRL to LEDs. Everything was plug & play, the taillights didn't need to get programmed from the dealer but the headlights did in order for the halos to work. A few days ago, I upgraded from halogen DRL to LED DRL. The first two days were fine until I noticed that when I try & use the right turn signal it give me a hyper flash. At first it was only the right side & today it happened to both. Usually they will correct themselves after I turn the Jeep off & start it back up & they will work properly with no hyper flash. Also, I do get an error on my dash saying the turn signals are out but like I said it's intermittent. The question I have is... Is this an electrical problem or do I simply need a bypass with a Tazer or a dealer code to be added in?
P.S. The actual DRL LED works fine, it's always on & doesn't give me any issues. It's just the turn signals!
If anyone else has an answer or has been through a similar situation please chime on in on your fix!
Thank you :)
Jeep Wrangler JL Halogen to LED DRL - Do I need a dealer code? 20200620_115049
Kenny
Ken
Utah
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
Good Morning,
Thank you :)
You might need to put a resistor in the circuit. I had the dealer Put in ?LED code - still had the hyper flash. Resistor took care of it
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Good Morning,
Thank you :)
Surprised the DRLs are working properly unless whatever dealer did for halos changed something. I have a tazer mini and it’s great. Utilized for tire size, LED fogs, LED DRLs/turn signals, and disabled ESS. Is your speedo not calibrated?
ZgsProduct
ZgsProduct
Pure Michigan
2018 JLUR 1987 YJ
That's what I'm saying, because the gentlemen I purchased these from said I definitely will need to get it flashed because the DRLs simply won't even turn on so I was surprised that they did. My speedometer is off by about 5-7 MPH currently. I'm not too bothered by it honestly but a Tazer might be my next investment.
ZgsProduct
ZgsProduct
Pure Michigan
2018 JLUR 1987 YJ
Nice, did you also upgrade from non-LED to LED DRL? If so, did you go factory DRLs or aftermarket? & what resistor did you go with, link me if you can ;)
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
I also believe calibration assist with transmission shift points. You may want to consider doing. The stupid ESS drove me crazy. My DRLs and turn signals act differently with headlights on then during the day. During the day DRL goes off when turn signal on. Headlights on they stay on. I think this is strange but may be normal.
Gregj
Greg
West Texas
JLU Rubicon, JLU Sport, JTuRD
Completely normal. They act as running lights when the lights are on. They are at a lower light level with the lights on.
Gregj
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Gregj
Thanks Greg. So I just read up again and I may play around with setting “DRL Dropout” to see changes how they act. :like:
Kenny
Ken
Utah
Village Idiot
went from halogen to OEM DRL. - I only had issues with the fog - everything else worked with the code change
Alasek
Chula Vista CA
2018 Jeep Wrangler JL
What’s up man what was the code for the drl? I just dropped off my car at the dealer but they don’t know which code would make the drl led work
LHuffman47
Lucas
Glendale
2018 JL Sahara
Automotive Sales Manager
My DRL's work the majority of the time. Probably 90%. When they dont work it says the bulbs are out up front, would this be a resistor, or need coded?
Kenny
Ken
Utah
Village Idiot
it’s for LE D headlights - you need to pull the wire for theDRLs to work
humrk311
Ron
Ashford CT
2018 Wrangler Sahara Unlimited / 1999 BMW R1100S / 1998 BMW M3
Good Morning,
Thank you :)
Been there..
Since your Rubi didn't come with (at least) LED tail lights there's no flash that will make the front fender LED turn signals work. There were rumors (on this forum and elsewhere) of a non-published "sales code" that would only be provided by the Region sales manager upon request of the dealer service manager..
I spent a ton of time with my dealer and with various Jeep reps in an effort to identify that code... even tracked down a service manager who (as referenced in a post) had actually secured that sales code.. he informed me the post was incorrect, when I contacted the original poster he confirmed that was the case..
Bottom line - the rumored sales code doesn't exist.. after additional researce I've concluded the root issue is the circuitry between the BCM and DRLs in non-Premium Lighting vehicles is different than in full LED vehicles..
Fortunately you can get around that by "fooling" the BCM with a Tazer (or similar)
Alasek
Chula Vista CA
Good Morning,
Thank you :)
Good Morning,
Thank you :)
I just installed my OEM drl led lights and brought it to the dealer to reprogram the BCM and they are working properly!
dgulia
Raj
Toledo, OH
2020 Jeep Wrangler Sport JLU; 2019 Ram 2500 Laramie; 2019 Jeep Cherokee
I am having the same issue. As soon as computer recognizes its a LED turn signal it throws an error and turn signals don't work. Its better to just buy a Tazer and get it over with that way you don't have to go dealer if you upgrade something else.
