blnewt
- Brad
- Oct 8, 2018
- New Mexico
- 2019 Jeep JL V6 SportS, (Retired 74 CJ-5, 80 CJ-7)
- Occupation
- Just ask @cosine he knows!
If you do go taller & wider w/ your tires and you do use the stock wheels you may need spacers to keep from inner contact when the suspension is under full flex, and the steering is at full lock. Downside is the narrowest spacers typically used are 1.25" thick so you will have some tire poking outside the fenders.In regards to #2, the stock rim is 7.5. I don't want to purchase new rims, but are you saying that in order to fit 35in (or the 315/70/17) tires, I need a wider rim? If I did get different rims, that would throw this whole thing off correct?
In regards to #3,
