Brake bleeding
MySabre
Sandston Va
2018 Jeep Wrangler
I have a 2018 JL that I just replaced both front calipers! On! The back caliper bleed went smoothly. The front, not so much! Im using the same method (vacuum method) on the front as I did the back! I’m getting hardly any fluid to come out of either front caliper! I even went old school and had a helper in the drivers seat pushing on the pedal, holding there foot down while I turned the bleed screw! Same result, the back caliper bleeding was smooth with no issues! The front, still can’t get hardly any fluid out of the bleed valves! What am I missing?
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
It takes some time to purge all that air, but if thats not really happening no matter what then:
Safe to assume a blockage of some sort. Start by removing the bleed fitting completely, pump the brake a few times and see if fluid comes out, If not the next disconnect point is going into the caliper. Disconnect that and try a light pump a few times, if fluid comes out you have a bad/blocked caliper, if not, keep working your way back till a disconnect eventually pumps fluid out and you will have the culprit.
Note, may want to keep a finger over each opening you create as your working backwards in the system just to see if you can feel the pressure from the pump.
azjl#3
North AZ
Stupid question, is air or more fluid able to get into master cylinder?
