Amazon camera. Mounted on the front of the cross member. Insulated the wire with heat shielding and ran in through the frame up through the driver side wheel well following the wiring harness. Hooked it up to my aux switch so I can turn it on and off.Both in one day sounds like quite the adventure! Way to go, you guys! I def would of needed a few beers after that haha. @Go1712 that video feed of the underside, what is your set up for that? That's so cool!
I pretty much did the majority of the trails sans spotter using that camera as my guide.Amazon camera. Mounted on the front of the cross member. Insulated the wire with heat shielding and ran in through the frame up through the driver side wheel well following the wiring harness. Hooked it up to my aux switch so I can turn it on and off.
Had to make a huge differenceI pretty much did the majority of the trails sans spotter using that camera as my guide.
It certainly was and I think we may have both been questioning whether we should have taken the second trail but once we were in we had no choice but to forge through and get it done. After we were done I felt pretty good that we were able to go through pretty smoothly and I know I learned a lot about strategy and not hesitating to fire up the winch when needed.Man, what a gauntlet
Yea that west end gatekeeper was smooth and at night. Would have been perfect.I check my cards and downloaded the videos. I don’t know what happened on JB but that card was empty
I do have HC from the start to just as we were wrapping up the middle rock garden. My card filled up and I didn’t put no a new one. I do wish I would have recorded the west end gatekeeper because I think that was my best section of the day after practicing actual smooth crawling all day and how to ease down the drops to set down soft and slide off gently with no banging.
And we learned to think, “The Floor is Lava”It certainly was and I think we may have both been questioning whether we should have taken the second trail but once we were in we had no choice but to forge through and get it done. After we were done I felt pretty good that we were able to go through pretty smoothly and I know I learned a lot about strategy and not hesitating to fire up the winch when needed.
